How do you prevent the battery from discharging when the phone is off?
1) How and when it charges kind of depends on the Operating System software, so no set rules there.
2) Watch the screen carefully when you shut it off, sometimes you can see if it powers down completely.
The screen will go completely black pretty quick.. If it just sort of fades away, you may need to hold the power button for it to completely power-down.
Remember the old Windows 98 and XP computers ? Some would actually turn off when you turned it off, but some
would go to a screen saying "It is Safe to Turn Off your Computer Now" ? Then you had to manually push the button to turn it off.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
a little offtopic.
I read that the piephone has an rtc, I remember the old phones that could turn on to work the alarm clock.
With android this seems to be no longer possible (maybe something to do with the rtc?) but once I happened a phone (very cheap, I don't remember if it was a mediatek) that could do it.
Maybe in the future it could be possible with the pinephone, planning phone turning off and on..
I'm not sure about the circutry in the Pinephone, - but it appears to need to be  'powered on'  to be able to charge the battery..?
So perhaps it could be the OS is needed to control the charging ?
Perhaps future models could have an independent charge control circut ahead of the main computer board ?
*(an independent circut could also have a clock function in it.)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(03-19-2020, 04:11 AM)bcnaz Wrote: but it appears to need to be  'powered on'  to be able to charge the battery..?
woot? so to be able to charge my phone, it needs to be powered on?! so i never should let it go off with a "empty" battery?
Then the phone would be broken by design. I can't imagine it is that way.
>  "Appears to be"  is only   'my impression'
  Besides,  you Did Read the warning disclosures posted everywhere before 'Buying this Phone'   ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
(03-19-2020, 03:44 PM)bcnaz Wrote:   Besides,  you Did Read the warning disclosures posted everywhere before 'Buying this Phone'   ?
yes and i am wondering if you understood what i wrote and meant with:
"Then the phone would be broken by design. I can't imagine it is that way."
(03-11-2020, 10:15 AM)supermagic Wrote: Seems like the battery discharges when the phone is off.
How do you prevent this?
I'm using terminal command 'sudo shutdown now'
  power circuit can't charge battery and can't supply enough power for modem or wifi vortex 2 364 02-17-2024, 04:15 PM
Last Post: vortex
  Phone will not turn on (but sometimes will) insidetrip101 10 4,367 08-18-2023, 04:28 AM
Last Post: spha
  Pine phone main board part Generaltuxenburg 1 915 07-31-2023, 07:50 PM
  Battery life improvement freelectro 10 2,943 06-01-2023, 08:27 PM
Thumbs Down Battery Issue or Power Management IC? bcoyle 2 1,411 03-20-2023, 12:54 AM
Last Post: bcoyle
  No calls on Pine Phone Beta convergence edition polypode 1 1,108 03-06-2023, 08:04 PM
Last Post: rocket2nfinity
  Pine phone USB keyboard connection CleanEnergyCleanEnvironment 1 1,052 02-20-2023, 12:14 AM
Thumbs Down Phone is unresponsive theneedful 14 7,180 08-12-2022, 08:18 AM
Last Post: theneedful
  Phone Dead Already? MarsColonist 4 2,546 08-11-2022, 11:52 AM
Last Post: auanta
  Power supply vs battery albafrati 11 4,325 06-22-2022, 06:04 PM
Last Post: albafrati
