OS Suitable for 2GB MicroSD?
Hey guys, I received my Pine in the mail yesterday only to discover that I've misplaced my wondrously important 8GB card. Only one I have on hand until my Amazon order comes in is a 2GB one, and I'm curious if there's an OS image out there yet small enough to run on it.
Doesn't have to be anything special, even just a command line to tinker with would be fine. Preferably Linux based.
All help is appreciated  Cool
Not that I know of, but there is a debian build coming which should fit on a 2gb card.
You can take a look here at available imgs:
https://www.pine64.pro/downloads/
or here on the official wiki:
http://wiki.pine64.org/index.php/Pine_A6...re_Release
Use the simple image I provide and combine it with any rootfs you want with the partition size you want and don't forget the kernel modules. Trivial when you have some skills in that area.
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,701 08-07-2022, 10:47 AM
Last Post: commiecam
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 151,085 01-15-2020, 12:46 PM
  Rock64 suitable for headless TVHeadend install? elsmandino 3 6,471 06-26-2018, 11:37 AM
Last Post: Luke
  corrupt microsd card after reboot maxpayne 6 10,087 02-08-2017, 05:42 PM
Last Post: maxpayne
  Using 4GB microSD eunf 1 2,570 07-30-2016, 01:24 PM
Last Post: MarkHaysHarris777
  Great microSD on discount! SkimMilk 3 4,497 07-20-2016, 10:11 PM
Last Post: SkimMilk
  Partitioning MicroSD card for boot/storage KillrKowalski 6 7,701 05-04-2016, 07:13 AM
Last Post: Leoncito81
Question creating bootable remixOS/android MicroSD on Mac OS X or linux? faddah 3 13,880 04-18-2016, 09:46 AM
