BUG: spinlock lockup suspected | .magic: dead4ead, .owner: scsi_eh_2/264, .owner_cpu
Hi guys,
I'm a few weeks busy with setting up my Pine64 NASCase with a ROCKPro 64 4GB SBC together with a 3TB WD Red HDD.
Bought the NASCasefrom the Pine Shop together with all related:
  • ROCKPro64 4GB Single Board Computer
  • ROCKPro64 30mm Tall Profile Heatsink
  • ROCKPro64 Metal Desktop/NAS Casing
  • Fan for ROCKPro64 Metal Desktop/NAS casing
  • ROCKPro64 12V 5A EU POWER SUPPLY
  • ROCKPro64 PCI-e to Dual SATA-II Interface Card
  • 32GB eMMC Module
  • USB Adapter for eMMC Module
I want to run OpenMediaVault as NAS-server but I got the error "communication failure" everytime I want to create a filesystem under [Storage - File Systems]
Just 1 disk , not even RAID...
Meanwile the GUI showed this:
Creating the file system, please wait ...
===== Wipe signatures from device =====
===== Create partition =====
Creating new GPT entries.
Disk /dev/sda: 5860533168 sectors, 2.7 TiB
Model: WDC WD30EFRX-68E
Sector size (logical/physical): 512/4096 bytes
Disk identifier (GUID): F5A4F6BA-7EB3-4A91-A62E-E252BD48E752
Partition table holds up to 128 entries
Main partition table begins at sector 2 and ends at sector 33
First usable sector is 34, last usable sector is 5860533134
Partitions will be aligned on 2048-sector boundaries
Total free space is 2014 sectors (1007.0 KiB)
Number Start (sector) End (sector) Size Code Name
1 2048 5860533134 2.7 TiB 8300
The operation has completed successfully.
===== Create file system =====
mke2fs 1.44.5 (15-Dec-2018)
Creating filesystem with 732566385 4k blocks and 183148544 inodes
Filesystem UUID: 3ef041b7-0a33-46ee-a903-2ccf09f1b7e7
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424, 20480000, 23887872, 71663616, 78675968,
102400000, 214990848, 512000000, 550731776, 644972544
Allocating group tables: 0/22357 done
Writing inode tables: 0/22357 96/22357 254/22357 319/22357 351/22357 362/22357 366/22357
Logging from the command line:
|_ \ ______| | _|_ \ _ __ ___/ /_ | || |
|_) / _ \ / __| |/ / |_) | '__/ _ \| '_ \| || |_
< (_) | (__|<|__/| | | (_) | | (_) |___|
| \_\___/ \___|_|\_\_||_|\___/\___/|_|
Welcome to Armbian buster with Linux 4.4.210-rockchip64
System load:   2.13 0.66 0.23  Up time:       0 min
Memory usage:  10 % of 3874MB IP:            192.168.2.3
CPU temp:      51°C
Usage of /:    17% of 15G
last login: Sun Feb  2 19:08:55 2020 from 192.168.2.106
root@NAS-rockpro64:~# mkfs.ext4 /dev/sda
Creating filesystem with 732566646 4k blocks and 183148544 inodes
Filesystem UUID: 21668c66-fbee-4fd2-8e1f-2127a8c48970
Allocating group tables: done
Writing inode tables: done
Creating journal (262144 blocks):
Message from syslogd@NAS-rockpro64 at Feb  3 18:04:10 ...
 kernel:[  121.843550] Internal error: : 96000210 [#1] SMP
 kernel:[  129.131405] BUG: spinlock lockup suspected on CPU#0, scsi_eh_0/274
kernel:[  129.135057]  lock: 0xffffff8009321870, .magic: dead4ead, .owner: scsi_eh_0/274, .owner_cpu: 0
Tried the OS from SD-card and now from the eMMC-module, tried several OS's but problems remains
Put the 3TB WD Red HDD in an external case with his own power supply
Connected via USB3 between RockPro64 (with the original 12V/5A power supply) and the external case
Now it formats without problems...
  1. Creating the file system, please wait ...
  2. ===== Wipe signatures from device =====
  3. ===== Create partition =====
  4. Creating new GPT entries.
  5. Disk /dev/sda: 5860533168 sectors, 2.7 TiB
  6. Model: 2115
  7. Sector size (logical/physical): 512/4096 bytes
  8. Disk identifier (GUID): 4B88D686-DF00-4662-B856-982CE6915F94
  9. Partition table holds up to 128 entries
  10. Main partition table begins at sector 2 and ends at sector 33
  11. First usable sector is 34, last usable sector is 5860533134
  12. Partitions will be aligned on 2048-sector boundaries
  13. Total free space is 2014 sectors (1007.0 KiB)
  14. Number  Start (sector)    End (sector)  Size       Code  Name
  15.   1            2048      5860533134   2.7 TiB     8300
  16. The operation has completed successfully.
  17. ===== Create file system =====
  18. mke2fs 1.44.5 (15-Dec-2018)
  19. Creating filesystem with 732566385 4k blocks and 183148544 inodes
  20. Filesystem UUID: d10909a1-56b5-4e6c-9588-b70c2f464e3c
  21. Superblock backups stored on blocks:
  22. 32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
  23. 4096000, 7962624, 11239424, 20480000, 23887872, 71663616, 78675968,
  24. 102400000, 214990848, 512000000, 550731776, 644972544
  25. Allocating group tables:     0/22357           done
  26. Writing inode tables:     0/22357    4/22357  229/22357  327/22357  410/22357  459/22357  508/22357  557/22357  605/22357  654/22357  702/22357  751/22357  799/22357  846/22357  892/22357  938/22357  983/22357 1028/22357 1073/22357 1118/22357 1163/22357 1208/22357 1252/22357 1297/22357 1342/22357 1387/22357 1432/22357 1477/22357 1522/22357 1567/22357 1612/22357 1657/22357 1702/22357 1747/22357 1793/22357 1842/22357 1889/22357 1936/22357 1985/22357 2032/22357 2080/22357 2125/22357 2170/22357 2217/22357 2264/22357 2312/22357 2360/22357 2408/22357 2455/22357 2502/22357 2551/22357 2598/22357 2646/22357 2692/22357 2739/22357 2786/22357 2835/22357 2881/22357 2927/22357 2975/22357 3022/22357 3070/22357 3117/22357 3166/22357 3214/22357 3261/22357 3309/22357 3357/22357 3405/22357 3452/22357 3500/22357 3545/22357 3592/22357 3639/22357 3688/22357 3734/22357 3780/22357 3828/22357 3875/22357 3924/22357 3970/22357 4018/22357 4063/22357 4112/22357 4159/22357 4208/22357 4255/22357 4304/22357 4352/22357 4397/22357 4443/22357 4488/22357 4537/22357 4582/22357 4630/22357 4678/22357 4723/22357 4770/22357 4817/22357 4865/22357 4912/22357 4958/22357 5004/22357 5052/22357 5099/22357 5148/22357 5195/22357 5244/22357 5291/22357 5339/22357 5385/22357 5431/22357 5480/22357 5525/22357 5572/22357 5619/22357 5664/22357 5710/22357 5756/22357 5803/22357 5851/22357 5900/22357 5947/22357 5997/22357 6043/22357 6091/22357 6138/22357 6186/22357 6232/22357 6281/22357 6327/22357 6375/22357 6421/22357 6467/22357 6515/22357 6562/22357 6610/22357 6657/22357 6706/22357 6753/22357 6803/22357 6850/22357 6897/22357 6944/22357 6993/22357 7040/22357 7089/22357 7136/22357 7184/22357 7233/22357 7281/22357 7330/22357 7374/22357 7420/22357 7465/22357 7513/22357 7559/22357 7607/22357 7653/22357 7699/22357 7746/22357 7792/22357 7840/22357 7887/22357 7932/22357 7980/22357 8028/22357 8074/22357 8122/22357 8169/22357 8218/22357 8264/22357 8312/22357 8360/22357 8408/22357 8456/22357 8504/22357 8551/22357 8599/22357 8644/22357 8689/22357 8734/22357 8781/22357 8828/22357 8875/22357 8921/22357 8969/22357 9015/22357 9060/22357 9105/22357 9150/22357 9197/22357 9244/22357 9291/22357 9337/22357 9384/22357 9429/22357 9474/22357 9519/22357 9566/22357 9612/22357 9657/22357 9704/22357 9753/22357 9799/22357 9847/22357 9893/22357 9941/22357 9986/2235710037/2235710083/2235710130/2235710175/2235710223/2235710269/2235710317/2235710363/2235710408/2235710454/2235710502/2235710548/2235710593/2235710638/2235710683/2235710730/2235710776/2235710824/2235710871/2235710919/2235710966/2235711012/2235711057/2235711104/2235711151/2235711198/2235711246/2235711292/2235711337/2235711383/2235711428/2235711474/2235711520/2235711567/2235711613/2235711659/2235711704/2235711750/2235711796/2235711842/2235711889/2235711935/2235711983/2235712029/2235712076/2235712122/2235712168/2235712214/2235712260/2235712306/2235712351/2235712396/2235712443/2235712488/2235712535/2235712580/2235712628/2235712674/2235712721/2235712767/2235712814/2235712859/2235712905/2235712953/2235712998/2235713044/2235713090/2235713135/2235713181/2235713227/2235713273/2235713320/2235713365/2235713410/2235713458/2235713503/2235713548/2235713594/2235713639/2235713686/2235713733/2235713778/2235713824/2235713869/2235713917/2235713962/2235714009/2235714053/2235714098/2235714144/2235714190/2235714235/2235714280/2235714327/2235714372/2235714416/2235714461/2235714507/2235714552/2235714600/2235714649/2235714694/2235714739/2235714785/2235714831/2235714879/2235714927/2235714972/2235715018/2235715064/2235715110/2235715155/2235715200/2235715244/2235715290/2235715337/2235715384/2235715431/2235715477/2235715522/2235715567/2235715613/2235715660/2235715705/2235715751/2235715798/2235715844/2235715891/2235715938/2235715985/2235716031/2235716078/2235716124/2235716169/2235716214/2235716259/2235716304/2235716348/2235716393/2235716438/2235716483/2235716528/2235716573/2235716618/2235716662/2235716707/2235716752/2235716797/2235716841/2235716886/2235716931/2235716976/2235717022/2235717067/2235717112/2235717157/2235717202/2235717247/2235717292/2235717337/2235717381/2235717426/2235717471/2235717515/2235717560/2235717605/2235717649/2235717694/2235717739/2235717783/2235717828/2235717873/2235717917/2235717962/2235718007/2235718051/2235718096/2235718141/2235718185/2235718229/2235718273/2235718316/2235718360/2235718403/2235718446/2235718489/2235718530/2235718572/2235718613/2235718654/2235718694/2235718735/2235718775/2235718815/2235718855/2235718895/2235718935/2235718975/2235719015/2235719055/2235719096/2235719136/2235719175/2235719216/2235719257/2235719298/2235719339/2235719380/2235719421/2235719461/2235719502/2235719543/2235719583/2235719623/2235719663/2235719703/2235719743/2235719783/2235719823/2235719863/2235719903/2235719943/2235719983/2235720024/2235720064/2235720104/2235720144/2235720184/2235720224/2235720264/2235720304/2235720344/2235720384/2235720423/2235720463/2235720502/2235720541/2235720580/2235720618/2235720656/2235720694/2235720731/2235720769/2235720806/2235720843/2235720880/2235720917/2235720953/2235720990/2235721027/2235721063/2235721100/2235721136/2235721173/2235721209/2235721245/2235721282/2235721318/2235721354/2235721390/2235721426/2235721463/2235721499/2235721535/2235721571/2235721607/2235721643/2235721678/2235721713/2235721747/2235721780/2235721814/2235721847/2235721880/2235721913/2235721947/2235721980/2235722013/2235722046/2235722079/2235722113/2235722146/2235722179/2235722212/2235722245/2235722279/2235722312/2235722345/22357           done
  27. Creating journal (262144 blocks): done
  28. Writing superblocks and filesystem accounting information:     0/22357           done
  29. The file system creation has completed successfully.
I found at my computing stuff a WD 1TB Green Caviar HDD and tried it without the external power supply, similar like before with the 3TB WD Red HDD
Got the same errors as before , but it took a little longer before the system crashed
  5. Disk /dev/sda: 1953525168 sectors, 931.5 GiB
  6. Model: WDC WD10EADS-00L
  7. Sector size (logical/physical): 512/512 bytes
  8. Disk identifier (GUID): 1E8AE397-E393-4A56-8835-5F9A81FA53CB
  11. First usable sector is 34, last usable sector is 1953525134
  15.   1            2048      1953525134   931.5 GiB   8300
  19. Creating filesystem with 244190385 4k blocks and 61054976 inodes
  20. Filesystem UUID: 88b18685-3bde-4609-99d8-539883efb79f
  25. Allocating group tables:    0/7453         done
  26. Writing inode tables:    0/7453  45/7453 241/7453 317/7453 366/7453 414/7453 463/7453 511/7453 557/7453 600/7453 641/7453 680/7453 720/7453 759/7453 798/7453 838/7453 863/7453 871/7453 874/7453
  1. ____            _    ____               __   _  _
  2. |  _ \ ___   ___| | _|  _ \ _ __ ___    / /_ | || |
  3. | |_) / _ \ / __| |/ / |_) | '__/ _ \  | '_ \| || |_
  4. |  _ < (_) | (__|   <|  __/| | | (_) | | (_) |__   _|
  5. |_| \_\___/ \___|_|\_\_|   |_|  \___/   \___/   |_|
  6. Welcome to Armbian buster with Linux 4.4.208-rockchip64
  7. System load:   0.11 0.07 0.02   Up time:       2:41 hours
  8. Memory usage:  5 % of 3874MB Zram usage:    2 % of 1937Mb IP:            192.168.2.3
  9. CPU temp:      36°C
  10. Usage of /:    7% of 29G
  11. [ General system configuration (beta): armbian-config ]
  12. Last login: Wed Feb  5 17:21:39 2020 from 192.168.2.106
  13. root@rockpro64:~#
  14. Message from syslogd@localhost at Feb  5 19:57:03 ...
  15. kernel:[ 9735.004750] Internal error: : 96000210 [#1] SMP
  16. Message from syslogd@localhost at Feb  5 19:57:10 ...
  17. kernel:[ 9742.274127] BUG: spinlock lockup suspected on CPU#0, scsi_eh_2/264
  18. Message from syslogd@localhost at Feb  5 19:57:10 ...
  19. kernel:[ 9742.277966]  lock: 0xffffff8009321870, .magic: dead4ead, .owner: scsi_eh_2/264, .owner_cpu: 0
  20. Message from syslogd@localhost at Feb  5 19:58:48 ...
  21. kernel:[ 9840.525926] Kernel panic - not syncing: hung_task: blocked tasks
How to bring it down to the specific cause?
Power supply or PCI-SATA card or ?
Faulty or failing hardware or failing power or caused by software?
I installed bionic-minimal-rockpro64-0.9.16-1163-armhf.img.xz from https://github.com/ayufan-rock64/linux-build/releases/tag/0.9.16
with the updates:
sudo apt-get update -y && sudo apt-get install linux-rockpro64-0.9 -y
sudo apt-get update -y && sudo apt-get dist-upgrade -y
I opened a second ssh session with the command:
tail -f /var/log/syslog
and did some debugging with the command:
mkfs.ext4 /dev/sda
here is the log:
Welcome to Ubuntu 18.04.4 LTS (GNU/Linux 4.4.197-1236-rockchip-ayufan-g30faab37e339 aarch64)
                _                     __   _  _
 _ __ ___   | | ___ __  _ __ ___  / / | || |
| '/ _ \ / [i]| |/ / ' | '[/i]/ _ | '_ | || |_
| | | (_) | (
|   <| |[i]) | | | () | (_) |[/i]_   |
|  _/ _||_\ .__/||  _/ _/   ||
 * Documentation:  https://help.ubuntu.com
 * Management:     https://landscape.canonical.com
 * Support:        https://ubuntu.com/advantage
  System information as of Sun Feb 16 15:20:07 UTC 2020
  System load:  0.14              Processes:           168
  Usage of /:   5.3% of 28.42GB   Users logged in:     1
  Memory usage: 2%                IP address for eth0: 192.168.2.3
  Swap usage:   0%
 * Multipass 1.0 is out! Get Ubuntu VMs on demand on your Linux, Windows or
   Mac. Supports cloud-init for fast, local, cloud devops simulation.
     https://multipass.run/
Last login: Sun Feb 16 15:17:51 2020 from 192.168.2.106
rock64@rockpro64:~$ tail -f /var/log/syslog
Feb 16 15:17:49 rockpro64 systemd[774]: Reached target Sockets.
Feb 16 15:17:49 rockpro64 systemd[774]: Reached target Timers.
Feb 16 15:17:49 rockpro64 systemd[774]: Reached target Basic System.
Feb 16 15:17:49 rockpro64 systemd[774]: Reached target Default.
Feb 16 15:17:49 rockpro64 systemd[774]: Startup finished in 184ms.
Feb 16 15:17:49 rockpro64 systemd[1]: Started User Manager for UID 1000.
Feb 16 15:18:01 rockpro64 CRON[830]: (root) CMD (for i in
pgrep "ftpd|nfsiod|smbd|afpd|cnid"
 ; do ionice -c1 -p $i ${XU4_HMP_Fix}; done &>/dev/null)
Feb 16 15:19:01 rockpro64 CRON[835]: (root) CMD (for i in
Feb 16 15:20:01 rockpro64 CRON[842]: (root) CMD (for i in
Feb 16 15:20:07 rockpro64 systemd[1]: Started Session 11 of user rock64.
Feb 16 15:21:01 rockpro64 CRON[897]: (root) CMD (for i in
Feb 16 15:21:30 rockpro64 kernel: [  410.987554] ata2.00: exception Emask 0x0 SAct 0x7effffff SErr 0x0 action 0x6 frozen
Feb 16 15:21:30 rockpro64 kernel: [  410.988489] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  410.989238] ata2.00: cmd 61/40:00:40:e8:85/05:00:ae:00:00/40 tag 0 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  410.989238]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  410.990973] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  410.991420] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  410.992056] ata2.00: cmd 61/40:08:80:ed:85/05:00:ae:00:00/40 tag 1 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  410.992056]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  410.993900] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  410.994359] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  410.994995] ata2.00: cmd 61/40:10:c0:f2:85/05:00:ae:00:00/40 tag 2 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  410.994995]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  410.996811] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  410.997272] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  410.997908] ata2.00: cmd 61/40:18:00:f8:85/05:00:ae:00:00/40 tag 3 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  410.997908]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  410.999625] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.000068] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.000795] ata2.00: cmd 61/40:20:40:fd:85/05:00:ae:00:00/40 tag 4 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.000795]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.002530] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.002974] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.003609] ata2.00: cmd 61/40:28:80:02:86/05:00:ae:00:00/40 tag 5 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.003609]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.005431] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.005879] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.006514] ata2.00: cmd 61/40:30:c0:07:86/05:00:ae:00:00/40 tag 6 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.006514]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.008022] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.008403] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.008968] ata2.00: cmd 61/40:38:00:0d:86/05:00:ae:00:00/40 tag 7 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.008968]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.010471] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.010852] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.011395] ata2.00: cmd 61/40:40:40:12:86/05:00:ae:00:00/40 tag 8 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.011395]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.012943] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.013326] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.013870] ata2.00: cmd 61/40:48:80:17:86/05:00:ae:00:00/40 tag 9 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.013870]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.015371] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.015751] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.016295] ata2.00: cmd 61/40:50:c0:1c:86/05:00:ae:00:00/40 tag 10 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.016295]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.017851] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.021465] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.025255] ata2.00: cmd 61/40:58:00:22:86/05:00:ae:00:00/40 tag 11 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.025255]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.033208] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.036768] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.040422] ata2.00: cmd 61/40:60:40:27:86/05:00:ae:00:00/40 tag 12 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.040422]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.048219] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.051419] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.054501] ata2.00: cmd 61/40:68:80:2c:86/05:00:ae:00:00/40 tag 13 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.054501]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.061055] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.063968] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.067066] ata2.00: cmd 61/40:70:c0:31:86/05:00:ae:00:00/40 tag 14 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.067066]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.073633] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.076588] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.079646] ata2.00: cmd 61/40:78:00:37:86/05:00:ae:00:00/40 tag 15 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.079646]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.086228] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.089029] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.091678] ata2.00: cmd 61/40:80:40:3c:86/05:00:ae:00:00/40 tag 16 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.091678]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.097416] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.099930] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.102607] ata2.00: cmd 61/40:88:80:41:86/05:00:ae:00:00/40 tag 17 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.102607]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.108357] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.110774] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.113115] ata2.00: cmd 61/40:90:c0:46:86/05:00:ae:00:00/40 tag 18 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.113115]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.118185] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.120369] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.122711] ata2.00: cmd 61/40:98:00:4c:86/05:00:ae:00:00/40 tag 19 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.122711]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.127790] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.130003] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.132327] ata2.00: cmd 61/40:a0:40:51:86/05:00:ae:00:00/40 tag 20 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.132327]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.137407] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.139600] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.141946] ata2.00: cmd 61/40:a8:80:56:86/05:00:ae:00:00/40 tag 21 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.141946]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.147043] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.149225] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.151329] ata2.00: cmd 61/40:b0:c0:5b:86/05:00:ae:00:00/40 tag 22 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.151329]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.155970] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.157968] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.160073] ata2.00: cmd 61/40:b8:00:61:86/05:00:ae:00:00/40 tag 23 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.160073]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.164719] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.166698] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.168824] ata2.00: cmd 61/40:c8:c0:c8:85/05:00:ae:00:00/40 tag 25 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.168824]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.173477] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.175449] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.177578] ata2.00: cmd 61/40:d0:00:ce:85/05:00:ae:00:00/40 tag 26 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.177578]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.182221] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.184195] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.186336] ata2.00: cmd 61/40:d8:40:d3:85/05:00:ae:00:00/40 tag 27 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.186336]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.190676] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.192481] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.194438] ata2.00: cmd 61/40:e0:80:d8:85/05:00:ae:00:00/40 tag 28 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.194438]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.198734] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.200553] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.202490] ata2.00: cmd 61/40:e8:c0:dd:85/05:00:ae:00:00/40 tag 29 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.202490]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.206798] ata2.00: status: { DRDY }
Feb 16 15:21:30 rockpro64 kernel: [  411.208615] ata2.00: failed command: WRITE FPDMA QUEUED
Feb 16 15:21:30 rockpro64 kernel: [  411.210414] ata2.00: cmd 61/40:f0:00:e3:85/05:00:ae:00:00/40 tag 30 ncq 688128 out
Feb 16 15:21:30 rockpro64 kernel: [  411.210414]          res 40/00:00:00:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
Feb 16 15:21:30 rockpro64 kernel: [  411.214423] ata2.00: status: { DRDY }
Feb 16 15:21:31 rockpro64 kernel: [  411.216102] ata2: hard resetting link
packet_write_wait: Connection to 192.168.2.3 port 22: Broken pipe
ATA controller:
rock64@rockpro64:~$ lspci |grep ATA
01:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 01)
and this hard drive:
rock64@rockpro64:~$ sudo smartctl -a /dev/sda |grep Model
Model Family:     Western Digital Red
Device Model:     WDC WD30EFRX-68EUZN0
here's the HDD's SMART report:
smartctl 6.6 2016-05-31 r4324 [aarch64-linux-4.4.197-1236-rockchip-ayufan-g30faab37e339] (local build)
Copyright © 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Serial Number:    WD-WCC4N6JZS316
LU WWN Device Id: 5 0014ee 2111b9f23
Firmware Version: 82.00A82
User Capacity:    3,000,592,982,016 bytes [3.00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Feb 16 15:42:12 2020 UTC
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: (42420) seconds.
capabilities:  (0x7b) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time:  (   2) minutes.
Extended self-test routine
recommended polling time:  ( 425) minutes.
Conveyance self-test routine
recommended polling time:  (   5) minutes.
SCT capabilities:        (0x703d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   185   176   021    Pre-fail  Always       -       5750
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       525
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   098   098   000    Old_age   Always       -       1808
 10 Spin_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   100   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       469
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       48
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       590
194 Temperature_Celsius     0x0022   122   113   000    Old_age   Always       -       28
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   200   200   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
1  Extended offline    Completed without error       00%      1335         -
2  Extended offline    Completed without error       00%      1187         -
3  Extended offline    Completed without error       00%      1062         -
4  Extended offline    Completed without error       00%       862         -
5  Extended offline    Completed without error       00%       696         -
6  Extended offline    Completed without error       00%       549         -
7  Extended offline    Completed without error       00%       411         -
8  Extended offline    Completed without error       00%       267         -
9  Extended offline    Completed without error       00%       121         -
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
As a layman myself, I see some "errors" with the dmesg command:
[ 1.479161] vcc5v0_host: no parameters
[ 1.479325] reg-fixed-voltage vcc5v0-host-regulator: vcc5v0_host supplying 0uV
[ 1.479966] iommu: Adding device ff650000.vpu_service to group 0
[ 1.480069] iommu: Adding device ff660000.rkvdec to group 1
[ 1.480166] iommu: Adding device ff670000.iep to group 2
[ 1.480293] iommu: Adding device ff8f0000.vop to group 3
[ 1.480388] platform ff8f0000.vop: iommu /iommu@ff8f3f00 not found
[ 1.480408] iommu: Removing device ff8f0000.vop from group 3
[ 1.480471] iommu: Adding device ff900000.vop to group 3
[ 1.480993] rk_iommu ff650800.iommu: can't get sclk
[ 1.481295] rk_iommu ff660480.iommu: can't get sclk
[ 1.481408] rk_iommu ff670800.iommu: can't get aclk
[ 1.481432] rk_iommu ff670800.iommu: can't get hclk
[ 1.481453] rk_iommu ff670800.iommu: can't get sclk
[ 1.481655] rk_iommu ff903f00.iommu: can't get sclk
[ 1.482036] SCSI subsystem initialized
[ 1.845571] phy phy-ff770000.syscon:usb2-phy@e460.1: Failed to get VBUS supply regulator
[ 1.851160] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree
[ 1.851268] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree
[ 1.851279] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed
[ 1.851294] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found
[ 1.851321] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree
[ 1.851331] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed
[ 1.851343] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found
[ 1.851367] rockchip-pcie f8000000.pcie: bus-scan-delay-ms in device tree is 1000 ms
[ 1.851400] rockchip-pcie f8000000.pcie: missing "memory-region" property
[ 1.851438] PCI host bridge /pcie@f8000000 ranges:
[ 1.851472] MEM 0xfa000000..0xfbdfffff -> 0xfa000000
[ 1.851495] IO 0xfbe00000..0xfbefffff -> 0xfbe00000
[ 1.898676] rockchip-pcie f8000000.pcie: invalid power supply
[ 1.935126] rockchip-pcie f8000000.pcie: wait 1000 ms (from device tree) before bus scan
[ 2.938931] rockchip-pcie f8000000.pcie: PCI host bridge to bus 0000:00
[ 3.135818] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[ 3.946085] i2c i2c-10: of_i2c: modalias failure on /dp@fec00000/ports
[ 3.947872] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 4.132784] xhci-hcd xhci-hcd.9.auto: Host not halted after 16000 microseconds.
[ 4.137214] xhci-hcd xhci-hcd.9.auto: Host controller not halted, aborting reset.
[ 4.951028] cdn-dp fec00000.dp: Direct firmware load for rockchip/dptx.bin failed with error -2
[ 14.382190] ff100000.saradc supply vref not found, using dummy regulator
[ 14.382297] rockchip-saradc ff100000.saradc: failed to get voltage
[ 14.386073] rockchip-saradc: probe of ff100000.saradc failed with error -22
[ 14.694857] FAT-fs (mmcblk0p6): utf8 is not a recommended IO charset for FAT filesystems, filesystem will be case sensitive!
[ 14.706800] [BT_RFKILL]: DISABLE UART_RTS
[ 14.706867] [BT_RFKILL]: bt turn on power
[ 14.712323] FAT-fs (mmcblk0p6): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Questions:
  1. I see many driver failures in de dmesg?
  2. Is this an incompatibility between the WD RED firmware and either the SATA Chipset and/or the mainboard it's self?
  3. How to be fixed?
Today I tried with another 12V / 4A power supply I found
And I received a new ordered 12V / 10A power supply
Again with both power supplies failures:
Message from syslogd@rockpro64 at Feb 20 21:20:33 ...
kernel:[ 193.381729] Internal error: Oops - bad mode: 0 [#1] SMP
kernel:[ 193.381788] Process nginx (pid: 1478, stack limit = 0xffffffc0eff44000)
Why is it that all my searches with all the failures I get on top are Rockpro / Arm boards?
Why is it that you don't reply to all my postings here on the Pine64 forum?
Is Pine64 having hardware problems?
Is Pine64 having driver problems?
Do I need to buy another PCI card which works without problems with the RockPro64 board?
Which (combinations of) hardware runs 100% without problems?
I bought this Pine64 NAS hardware for more then 200 euro's but it isn't running on different OS's for 2 minutes without problems!
How is Pine64 going to solve this?
Gr. Jeroen
Hello hemertje
i don't use OMV and i don't use Armbian.
OMV - i build my own NAS Smile
Armbian - is unstable!
And my experience, EMMC is unstable too.
So, my NAS is running for many month. ok, here is the Hardware.
  • Marvell 88SE9230 with 4 SATA Ports
  • ROCKPro64 with 2GB RAM
  • 2 * 3,5 Zoll HDD with 3TB as RAID 1
  • Sys is on an Portable SSD Samsung T5 on USB3 with 500GB
Software
Linux rockpro64 4.4.202-1237-rockchip-ayufan-gfd4492386213 #1 SMP Sat Nov 23 13:55:47 UTC 2019 aarch64 GNU/Linux
I am only using this release from Ayufan
https://github.com/ayufan-rock64/linux-b...m64.img.xz
This System is running very stable. No probs. I am using this for NFS, and do many backups in the night and so on.
I know, that it don't help you with OMV. But it is possible to use an ROCKPro64 as an stable headless system.
In my signature you found an link where you can read something about that Marvell card.
Greetings
Frank
P.S. Where is my PinePhone? Angry
Big Grin
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
Hi Frank,
Why are you using the SATA PCI adapter "Marvell 88SE9230 with 4 SATA Ports" and not Pine64's SATA adapter?
I read several / many problems with Pine64's SATA adapter...
PS. is it OK to post in English on your German forum?
Too many problems with pine64 sata adapter.
Yes, you can post in english on my forum. I will try to answer in correct english.
3. RockPro64 v2.1
Pine team offered me to send Rockpro64 and Sata adapter in as RMA
Will wait for now for new hardware...
(02-29-2020, 02:28 PM)hemertje Wrote: Pine team offered me to send Rockpro64 and Sata adapter in as RMA
Any update? I am having the exact same problem, PCI-e from Pine64 and a 2TB red WD harddrive. Consistently kernel panics whenever I try to create a new filesystem. Updated to newest ayufan kernel and even updated u-boot and still same issue.
For what it's worth, I received my RockPro64 last week and tried to set it up with 2 4TB WD Red drives - experienced the same problem while trying to copy files from one drive to another.  Essentially had to do it in small chunks - due to errors, the second drive I was copying stuff to would re-mount as read-only and I'd have to reboot and everything would be fine for a bit and then rinse and repeat.  Installed a Marvell 88SE9215 card and all of these problems went away.  So there's definitely a problem with the "official" ASMedia SATA card at least as far as using two hard drives at the same time.
When you installed the Marvell 88SE9215, was it working on first boot or did it require a kernel upgrade?
Quartz64, RockPro64, PinePhone Mobian, PineBook Pro, PineTime, and all the trimmings that make FOSS fun.
