Not quite, as we're currently more in a "rolling release" scheme. Upgrading using apt should be enough to get you there.
We're making small steps which doesn't justify a proper announcement, and there are still major bugs, so I'm holding back atm, but I hope we'll have a much improved release before the end of the month Smile
(05-09-2020, 03:18 AM)dukla2000 Wrote:
(05-09-2020, 01:51 AM)Juergen Wrote: Another problem occurred the second time to me: I shut down the phone yesterday 23.00, today the battery is totally discharged. (0%)
Can anyone confirm?
Yes, the modem doesn't power off correctly so unless you remove the battery you still have 1 ARM core (A53?)  running.
Perhaps this issue is already solved - just want to mention:
The last 3 weeks I used "sudo shutdown now" I had no problems, the phone lost maybe 1-2% over night.
With braveheart?
Sent from my iPhone using Tapatalk
I have a dependancy issue with libc6 when installing build-essential on braveheart.
E: Impossible de récupérer http://repo.mobian-project.org/pool/main/l/linux-5.6-pinephone/linux-libc-dev_5.6.0+pinephone5_arm64.deb  404  Not Found [IP : 91.121.79.211 80]
It looks like the path of the package is this package is
http://repo.mobian-project.org/pool/main..._arm64.deb
not
I post it there as I can't find the right place to post in on gitlab tracker
* PinePhone BraveHeart Edition
(06-15-2020, 03:44 AM)ivanB1975 Wrote: With braveheart?
yes
(06-15-2020, 07:57 AM)Gobelin Wrote: I have a dependancy issue with libc6 when installing build-essential on braveheart.
Your apt database is probably outdated, run apt update beforehand
Thanks, I really thought I ran apt upgrade several times, but I can't reproduce it. So I guess it was an outdated database. Thank you for your reply, and sorry for th inconvenience.
Hi All!
Anyone experienced that if you remove a software from the favourites, like Contacts it disappeares from the app grid?
Can I somehow link it back?
(06-16-2020, 01:36 AM)cefre00 Wrote: Hi All!
I also see the same problem with contact.
so I tested it with a calendar, but it looks good in the office if you take it out of the favorites.
Hey, I can't seem to apt update from the repo.mobian-project.org mobian Inrelease due to no public key available...what am I doing wrong? or has something changed with the location of the resource? GPG error.
Running PureOS with Phosh on a pinephone
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,850 03-25-2024, 09:07 AM
Last Post: anonymous
  unofficial kali linux for pinephone help needed pinesmell 5 3,583 01-08-2024, 02:50 PM
Last Post: ERPlegend
  Auto start application on Phosh login Zebulon Walton 8 3,296 10-14-2023, 06:29 AM
Last Post: alaraajavamma
  Problem with updates: Repository 'Debian bookworm' changed its 'non-free component' Anna 7 2,257 08-31-2023, 12:38 PM
Last Post: vusra
  Has anyone got briar-desktop running on mobian? vusra 5 2,966 06-19-2023, 03:02 PM
Last Post: vusra
  Using sway along phosh fdlamotte 2 3,282 05-11-2023, 04:24 PM
Last Post: kabouik
  Axolotl on PinePhone / Mobian arno_nuehm 219 163,958 03-26-2023, 01:49 AM
Last Post: shulamy
  PinePhone won't boot after software update jb2000 2 1,308 03-17-2023, 07:26 AM
Wink Pinephone lost graphic during mobian system upgrade cmpin 4 2,158 03-01-2023, 04:45 PM
  Mobian + phosh firefox ublock and other overlays display bugs tuxcall 3 1,758 02-24-2023, 12:11 AM
Last Post: nexion
