Cura anyone ?
Is there someone having success with installing Cura on the stock debian os ?
And if yes please share how Big Grin
"apt install cura" ?
cura is v3.3.1-2 in unstable.
(01-25-2020, 02:34 PM)bsammon Wrote: "apt install cura" ?
nope try yourself .. Big Grin
Have you tried the package from bionic? https://launchpad.net/ubuntu/bionic/arm64/cura/3.1.0-1
Nevermind, i just saw a post on their forums, where they indicated .deb files were discontinued due to packaging issues. Apparently, they're all in on appimages now.
you may have success with alt pinning either from unstable binaries or via source.
add the unstable repo on sources.list
create /etc/apt/preferences with:
Package: *
Pin: release a=unstable
Pin-Priority: 2
then
sudo apt-get update
sudo apt-get -t unstable install cura
or
sudo apt-get -t unstable build-dep cura
sudo apt-get -t unstable source -b cura
cura also has a git repo
(01-25-2020, 08:11 PM)tophneal Wrote: Have you tried the package from bionic? https://launchpad.net/ubuntu/bionic/arm64/cura/3.1.0-1
yep but the appimages doesn't work with the stock debian
What about a snap or flatpak?
(01-25-2020, 08:39 PM)xmixahlx Wrote: you may have success with alt pinning either from unstable binaries or via source.
Package: *
Pin-Priority: 2
then
sudo apt-get update
or
 thanks dude but nothing works.. anyway thanks for you efforts
(01-25-2020, 09:11 PM)tophneal Wrote: What about a snap or flatpak?
did't try it yet ... does not exist
Bummer! On the up side, It looks like they make source available to build it.
