ANSI PBP Keyboard Mapping for Tilde character
I noticed the tilde character is not mapped correctly. Also I noticed the double quotes and at symbol are swapped.
Can this be mapped somewhere to be corrected or is it in the ANSI keyboard firmware?
(01-14-2020, 08:27 PM)appdev46 Wrote: I noticed the tilde character is not mapped correctly.  Also I noticed the double quotes and at symbol are swapped.
   This is actually a software problem.
If you go into your 'keyboard menu'
You will find it says  EU keyboard.  You need to add US keyboard.
Then  Delete the EU keyboard,  that should resolve your problem.
I had the same issue.  My  @  key and  " keys were reversed.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
 That fixed my problem.  Thank you so much!!!
You are welcome
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  Replacing the Keyboard gabb 3 121 Yesterday, 02:50 AM
Last Post: dsimic
  Pinebook Pro Revised Keyboard Firmware jackhumbert 72 57,424 06-05-2021, 09:48 AM
Last Post: dsimic
  Some keyboard keys not working oddsocks 10 1,088 04-20-2021, 08:33 AM
Last Post: dsimic
  Spare parts / keyboard mbreese 2 964 01-07-2021, 07:40 AM
Last Post: dsimic
  How easy is it to add donor keyboard and trackpad? ENV 3 1,392 11-12-2020, 07:51 AM
Last Post: Kaythe
  Keyboard woes continue but somewhat improved kendew 6 1,916 10-27-2020, 09:34 PM
  Brand-new Pinebook Pro - keyboard not working guy100 8 3,105 10-09-2020, 10:49 AM
Last Post: guy100
  Keyboard: Multiple random Enter key presses budulay 1 1,033 10-05-2020, 12:12 AM
  Incorrectly asssembled keyboard ajtravis 1 984 09-22-2020, 09:38 AM
Last Post: josmo
Question Mouse unresponsive, keyboard issues...static noise after login mamboozo 0 740 09-01-2020, 09:48 PM
Last Post: mamboozo
