Mainline U-Boot with SPI, NVMe and SATA boot support
#69
(01-05-2021, 05:14 AM)jja2000 Wrote:
(12-16-2020, 12:21 PM)sigmaris Wrote:
(11-23-2020, 03:22 PM)Bullet64 Wrote: Hi @sigmaris , i am testing your u-boot 2020.10. When i boot from PCIe NVMe SSD boot process stuck @ "Booting using the fdt blob at 0x1f0000".
I've seen a few similar reports of the kernel not booting with recent mainline U-Boot, not just this build. Are you loading the u-boot env from SPI? If so, you could try removing the "usb start" from the "preboot" env variable to avoid initialising USB, as I read that having USB initialised by U-Boot might be related with the kernel not booting.
I'm running into the same problem. How do I remove usb start from the preboot env variable? Booting timeout is on 0 so I don't have the chance to mash any keys.
If I'm not mistaken, even with a timeout of 0 - there is a narrow window to stop the automatic boot process. Just had to mash keys in the UART console right as you turn your SBC on. At least that's how I was able to muck around in the uboot console.
RE: Mainline U-Boot with SPI, NVMe and SATA boot support - by amiraeva - 01-05-2021, 10:23 AM
  enble boot after power loss/restore dkebler 18 9,424 12-04-2023, 12:14 PM
Last Post: ok38
Bug Broken boot: What am I missing? mkosarek 1 666 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 4,252 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 4,317 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 1,548 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 8,187 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 1,150 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 2,797 07-02-2022, 09:24 AM
Last Post: dkebler
  ROCKPRO64 PCI SSD SD-boot Install pspgarret 0 1,163 06-09-2022, 10:56 AM
Last Post: pspgarret
  Support says "regulator" on the SBC burned out; how to fix? dmos 0 912 06-02-2022, 02:20 AM
Last Post: dmos
