Netflix with hardware acceleration not working
Good day Gentlemen & Gentlewomen,
I can't get the Chromium to work with the hardware accelartion.
Usually I wouldn't bother but its impossible to play videos from netflix like that (at least not in fullscreen mode).
Chromium gives me a error like this:
  • [12710:12710:1213/204638.585707:ERROR:gl_surface_egl.cc(1043)] : EGL display query failed with error EGL_SUCCESS
  • [12710:12710:1213/204638.585948:ERROR:gl_surface_egl.cc(1057)] : eglInitialize Default failed with error EGL_BAD_DISPLAY
  • [12710:12710:1213/204638.586005:ERROR:gl_initializer_x11.cc(156)] : GLSurfaceEGL::InitializeOneOff failed.
  • GpuProcessHost: The GPU process exited with code 1024.
I installed the latest libmali - wateland. I also tried some others, getting the same error.
Any hints / ideas ?
Thx in advance.
Problem solved.
Seems like I messed it up while playing with mali-libs... unfortunately I couldnt figure out which libs I screwed up, so at the end I decided to install a fresh image ....
Possibly Related Threads...
  Hardware Accelerated Video Playback Guide xkaiser 1 853 08-22-2019, 10:20 PM
Last Post: Mentaluproar
  Does anyone have kodi working? blahblahblah 6 881 07-19-2019, 08:09 AM
Last Post: PackElend
Information [archived] 0.8.X images from ayufan; Mate DE + video / 3d acceleration Luke 28 4,109 05-18-2019, 02:03 PM
Last Post: rickard
  Grabbing screenshot while hardware decoding StefanRvO 0 94 05-16-2019, 09:01 AM
Last Post: StefanRvO
  hardware pwm pins Mentaluproar 1 277 02-24-2019, 02:09 AM
  GPU acceleration for compositor Mentaluproar 1 302 01-29-2019, 05:18 PM
  Tutorial: OpenCL 1.2 FULL_PROFILE Working( moved for Tutorials Section ) tuxd3v 0 179 11-06-2018, 12:46 PM
Last Post: tuxd3v
  Linux not working properly (noobie) jannerman 2 367 10-21-2018, 08:58 PM
Last Post: tuxd3v
  Hardware Graphics Accelerator RuslanGennadievich 1 421 09-25-2018, 02:43 AM
Last Post: dukla2000
