Pinebook Pro 'xtreme'
#61
@xyzzy,
Yes, I am fully aware that a CHIP would be needed to translate PCIe to eMMC. It's just that NVMe is useless because it would, (as you rightly pointed out), add another layer of translation. Further more, NVMe is both a hardware standard, (basically PCIe), and a complex software interface standard. eMMC on the other hand is a bit simpler 8 bit parallel bus hardware interface and straight forward software interface.
Yes, it would be nice when SD cards have a PCIe interface. But, one of the problems with SD cards is that they generally do not have much longevity. Meaning an eMMC was designed to last the entire life of a phone, tablet or other device with on-board storage. That should be years of use. Many SD cards, (as many RaspberryPi people found out), don't last as long.
Lets not argue over something that you don't have to buy into. If I pursue it, and find its power consumption is more than expected, then I will drop it. That's one of the reasons I bought an open source laptop. I can choose to make changes. If they don't work, (or don't work well), so what?
Arwen Evenstar
Princess of Rivendale
  Pinebook Pro Initial Impressions kunger 443 584,845 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,238 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 376 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 280 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 273 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 206 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 637 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 707 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,478 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,171 12-15-2023, 02:11 PM
