Charging via USB-C
This is still a little unclear. Should we be using the USB C to charge?
If so PBP powered on or off?
Until handshake gets properly implemented - you can charge via USB-C reliably when the PBP is running or in suspend.
Photo P{inebook Pro not charging Ome Ko 6 4,919 11-09-2023, 03:29 PM
Last Post: tomekdev
  Pine Book Pro Charging Problems balin 7 10,963 12-15-2022, 02:15 PM
Last Post: tomasgreenro
  Very low battery (but charging) causes boot failures Phillip Bell 7 8,217 02-22-2022, 11:20 AM
  Pinebook Pro Stopped Charging via USB-C MickTheGeek 4 6,836 08-25-2021, 02:51 PM
Last Post: MickTheGeek
  HArdware issues while charging user18130814200115 2 4,459 05-01-2021, 04:13 AM
Last Post: gabeeg
  PineBookPro does not charging floppy_rofling 0 4,410 02-03-2021, 05:29 AM
Last Post: floppy_rofling
  Screen flicker with USB-C charging bchenlee609 5 9,250 01-25-2021, 08:48 PM
Last Post: bchenlee609
  USB-C Charging on the PBP? Paulie420 33 50,796 12-12-2020, 02:20 PM
Last Post: wrzomar
  Charging via USB-C Port tyha 15 28,173 07-22-2020, 08:15 PM
Last Post: iscmob
  Battery not charging via AC Adapter laissezfarrell 1 4,417 05-30-2020, 06:05 PM
