i3 Setup and Configuration
(11-16-2019, 07:13 PM)Axevy Wrote:
(11-09-2019, 09:32 AM)CandyAngel Wrote: Change LightDM configuration to add the `Sessions` widget so i3 can be chosen at login.
I don't understand this part, can someone please write the steps in order to get this part done ?
Thanks in advance.
Open the pine menu
Go in Administration and open "LightDM GTK+ Greeter settings"
Select the "Panel" tab
Click the "+" button
Select "Sessions menu" next to indicator
Click "Add' then "OK"
Click "Save" then "Close"
Next time you are on the login screen, you'll have a menu in the top right corner to switch window manager.
i3 Setup and Configuration - by CandyAngel - 11-09-2019, 09:32 AM
RE: i3 Setup and Configuration - by Axevy - 11-16-2019, 07:13 PM
RE: i3 Setup and Configuration - by IAteYourBacon - 11-17-2019, 03:14 AM
RE: i3 Setup and Configuration - by Keith - 01-12-2020, 11:46 PM
  Setup power profile from nvme bootscript korneliuszo 2 10,903 02-11-2020, 11:02 AM
Last Post: korneliuszo
