#71
(11-20-2019, 08:15 AM)PRStoetzer Wrote: but the window movement was smoother than on my much more powerful laptops. Very impressive!
Depending on your other systems, that might be due to the fixes that came with the current version 3.34 of Gnome Shell that Manjaro offers.
(11-20-2019, 08:15 AM)PRStoetzer Wrote: The three main problems I have with Manjaro ARM right now are getting hardware acceleration to work in Chromium so that 1080P videos are playable on YouTube, the lack of 5 GHz WiFi, and the lack of suspend.
The default Debian installation comes with the h264ify plugin installed, did you try that?
https://chrome.google.com/webstore/detai...kgioiakgal
#72
Music
Manjaro Preview 4 is out now:
https://forum.manjaro.org/t/manjaro-arm-...pro/112647
Changes listed as:
  • Fully working bluetooth
  • Fixed Wifi instability
  • Enable booting from NVMe - as in... placing the /boot partition on the eMMC/SD and the ROOT partition on the NVMe.
#73
Tried that today, wifi seems to be fixed.
Just redshift (still) does not seem to work and neither Retroarch does not run at full speed (tried Sega Genesis and PSX games). Using KDE.
#74
(11-25-2019, 06:07 AM)Wizzard Wrote: Tried that today, wifi seems to be fixed.
Night Light works well in Wayland sessions, for anyone wondering about the alternative.
Is Redshift still being held back by geoclue? I recall Redshift working on the PB1080 whenever you triggered it, or set the location manually. When attempting automatic, geoclue just never found itself.
#75
Any news on the hardware aceleration for the gpu?
#76
(11-25-2019, 07:14 AM)tophneal Wrote: Night Light works well in Wayland sessions, for anyone wondering about the alternative.
Tried Plasma Wayland session, but Night Light does not work and it is whole very slow, not usable for me.
#77
Bummer! Works very well under Gnome.
#78
Booted up nicely! I had some pops while changing volume.
Also intermittent high frequency noise coming from left speaker.
Wifi not a single problem for me.
edit: I'm a bit slow. this was manjaro kde plasma preview2
#79
How can I safety upgrade from P3 to P4?
Is there any way to be able to see my 5ghz WiFi networks?
Sent from my PH-1 using Tapatalk
#80
(11-25-2019, 02:38 PM)cristobalhdez Wrote: How can I safety upgrade from P3 to P4?
You can use the Add/Remove Software app, or terminal. In the app, open it, click on the Updates tab at the top, and the Apply button in the lower right corner. In terminal, use 'sudo pacman -Syu' (don't use the quotes.) Reboot after your updates are finished.
  Debian on Pinebook Pro u974615 8 444 03-22-2024, 03:57 PM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 168 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,116 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,607 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 215 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 1,916 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 1,979 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 86,631 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 291 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 993 11-23-2023, 07:37 AM
