Pardon my ignorance, but how do I install Manjaro XFCE (on SD card)? Do I just downlad straight from the downloads page on the Manjaro website (https://manjaro.org/download/) or is there a specific build for the pinebook pro? Is this where I go https://forum.manjaro.org/t/manjaro-arm-...pro/112647? When I click on the link for to download preview 4 with xfce here, I get 'page not found here https://osdn.net/projects/manjaro-arm/st.../preview4/.
I also feel a little lost
If I understand well, to build a bootable SDcard, I need to have a machine already running Manjaro and install the tools?
"The Manjaro project offers a mainline kernel with patches and modules to support PBPro hardware in two flavors. Both provide DD images and installer images (DD to SD card which will then install to eMMC when booted)."
https://wiki.pine64.org/index.php/Pinebo...anjaro_ARM
I've never been able to get boot with these images.
Is it normal after creating them with dd not to have a boot partition?
I used this command : sudo dd if=Manjaro-ARM-xfce-pbpro-19.12.1.img of=/dev/mmcblk0 bs=4k status=progress
Maybe try Etcher or the PINE64 Installer?
> bs=4k !!!!!!!
DON'T DO THAT
Hard on card, if nothing else, bloody slow
bs=1M is far better
(01-11-2020, 01:55 PM)zaius Wrote: "The Manjaro project offers a mainline kernel with patches and modules to support PBPro hardware in two flavors. Both provide DD images and installer images (DD to SD card which will then install to eMMC when booted)."
There’s also a Gnome Shell test build:
https://forum.manjaro.org/t/pinebook-pro...oad/113333
Bingo! I see it now. I'll get down to that later now that I know where to go (laptop is not with me right now). Thank you for pointing me in the right direction. The Wikipedia page is good. Smile
(01-11-2020, 01:48 PM)agD0i7rY Wrote: I also feel a little lost
I think I can answer that. Just use the operating system you already have on your pinebook pro to download the manjaro iso file. Download it straight to the SD card. Then make a bootable file out of it using the default software already on the computer (I think I saw 'installer' mentioned in a nearby post here, or else with 'dd etcher' (I hope I've got the name right there). Or else indeed do this from another computer with whatever operating system and tools that happen to be on it. I'm going to go at it myself straight from Debian mate on the pine this evening and I'll let u know how I get on. I think u might have to format the SD card first though even if it's new. I think I see the preferred format in a nearby post here. M1 I think it says.
I'm wrong about the meaning of 'dd'. It seems that refers to the option you choose if you want it to replace the existing o.s. on your emmc drive.
(01-11-2020, 02:23 PM)zaius Wrote: Maybe try Etcher or the PINE64 Installer?
I tried Etcher from another computer and it was the same.
I tried with several SD Cards, including one that booted with the official Debian.
I'll try to check with PINE64 installer.
(01-11-2020, 07:58 PM)wdt Wrote: > bs=4k    !!!!!!!
DON'T DO THAT
bs=1M  is far better
I had kept this option for a backup and resize of an SD.
Does it damage the card that much?
dd is the command to write to SD or emmc.
For the moment I would like to do it with SD to test Manjaro.
I had a Manjaro on my old computer that died...
I'm willing to get a description of your actions to set all this up. Smile
Thank you all!
(01-11-2020, 12:07 PM)leibide Wrote: Pardon my ignorance, but how do I install Manjaro XFCE (on SD card)? Do I just downlad straight from the downloads page on the Manjaro website (https://manjaro.org/download/) or is there a specific build for the pinebook pro? Is this where I go https://forum.manjaro.org/t/manjaro-arm-...pro/112647? When I click on the link for to download preview 4 with xfce here, I get 'page not found here https://osdn.net/projects/manjaro-arm/st.../preview4/.
That's an outdated image. Current release downloads can be found here: https://forum.manjaro.org/t/manjaro-arm-...sed/114406
Did you get that preview image from the wiki? We need to update it if so.
To install for booting off SD, download a PBP image without 'emmc-installer- in the filename to your computer. Use dd or an app to burn the image to SD (i.e. Etcher.) After that you can insert the SD into the PBP and boot from it.
  Debian on Pinebook Pro u974615 7 803 03-31-2024, 10:11 AM
Last Post: u974615
  Manjaro Sway Theme Broken Eighty8 1 258 03-08-2024, 08:41 AM
  Pinebook Pro upgrading from the factory image yamsoup 12 1,426 02-22-2024, 04:02 PM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,716 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 304 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,066 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,140 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 87,889 12-08-2023, 11:25 PM
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 383 12-07-2023, 03:11 PM
  Boot Order in Pinebook Pro food 8 1,170 11-23-2023, 07:37 AM
