Pinebook battery connector and reuse
Hello all,
Has anyone reused their pinebook battery for other than powering a pinebook?  Mine is in pieces right now, so I'm looking to reuse the parts I can.
Is the connector that the pinebook battery uses easy to acquire on Amazon or other sites online?  Would I have to de-solder the connector from the main board?  I tried to plugin a male end of GPIO jumper cable into one female outputs, but the pin is too thick.
The battery meters at around 4 ish volts, so I will need to boost it to 5 volts to run a raspberry pi.
Any thoughts or suggestions?
Power Distribution Tech and AV by trade, but I have been using Linux since around 2002.  I like the raspberry pi and pinebook pro, SBCs and the possibilities they open.
No suggestions? This is a perfectly good battery, I have a boost transformer to 5 volts already, but I want to be able to charge the battery too. There are 7 wires on this battery, 3 x 4 ish volt lines (red), 1 white (unknown purpose) and 3 ground (black). I looked at the PDF for the battery on the Wiki, but I didn't give me the information I was looking for.
My end goal is to power a raspberry pi 3b+ and an 3.5 display. It is going to be a small retro gaming system with arcade buttons wired into the GPIO pins (I have a pi cape to added extra ground pins and 5 volt and 3.3 volt pins). I'm looking for a UBEC that would work with this battery.
This is one guide I have been looking it:
https://www.instructables.com/id/Make-Yo...hargeable/
(10-17-2019, 10:35 AM)binholz Wrote: No suggestions?  This is a perfectly good battery, I have a boost transformer to 5 volts already, but I want to be able to charge the battery too.  There are 7 wires on this battery, 3 x 4 ish volt lines (red), 1 white (unknown purpose) and 3 ground (black).  I looked at the PDF for the battery on the Wiki, but I didn't give me the information I was looking for.
Try tagging one of the Pine team members, they should be able to help answer your connector question. I'm sure it's not too hard to find, as they seem to have an ease of sourcing in mind for most of their parts. If it is, you could probably find one of the RPi HATs that handles batter power/charging with it.
Possibly Related Threads...
  pinebook to pro upgrade path? dhosh 13 626 11-14-2019, 11:25 AM
Last Post: bcnaz
  Pinebook 11" Keyboard Corkonian 2 204 11-02-2019, 07:41 AM
Last Post: Corkonian
  [SOLVED] Pinebook stopped to charge UltraBloxX 7 472 10-17-2019, 04:09 AM
Last Post: pfeerick
  Barrel connector replacement or repair cel 1 286 08-18-2019, 01:40 PM
Last Post: cel
  Pinebook 1080p screen with other SBC? binholz 5 314 08-07-2019, 05:56 AM
Last Post: jezek
  Pinebook internals kodkuce 1 334 07-30-2019, 02:45 PM
Last Post: binholz
  how to install emmc in just arrived pinebook dkebler 11 6,573 06-13-2019, 01:13 AM
Last Post: zk1sps
  Pinebook Pro Video Out Options faroh8Je 2 184 06-12-2019, 05:16 AM
Last Post: Luke
  Pinebook HDMI not working DarkShadow 3 279 05-16-2019, 03:56 PM
Last Post: DarkShadow
  Pinebook Pro Network diagnostics hardware xavi 3 282 05-01-2019, 09:53 PM
