Which Pine or Rock for ~20-40$ is best for Boinc(Rosetta@home)
Hello. I wish to join Rosetta@home . I have close people
 with those disease. I see that android 4+ and arm is ok for this project. I thinking about buying 3-6 boards for this. Witch Pine or Rock computer do more job/more task at same time/ efficiency for this ? Is better  buy 2 SBC ~30$ or 1 SBD for~60$?  Sorry for my English
In terms of total front-end cost, you're much better off buying a single board since each needs its own microSD card and power supply; plus monitor, keyboard, mouse if not running "headless." As cheap as they are, these little things can get expensive fast if you let them.
Also, more long-term, 2 cards use more electricity than 1. This is a very real cost, though you probably won't notice it in your electric bill for such small devices...
If you can squeeze a little more into your budget, BOINC should be able to leverage the Mali GPU on the RockPro64, providing even more computational power than the (more powerful) CPU alone.
Sent from my moto x4 using Tapatalk
(09-08-2019, 04:34 AM)MarijusR Wrote: Hello. I wish to join Rosetta@home . I have close people
For your indicate budget, explore ROCK64 and ROCKPro64.
(09-08-2019, 05:28 PM)Paraplegic Racehorse Wrote: In terms of total front-end cost, you're much better off buying a single board since each needs its own microSD card and power supply; plus monitor, keyboard, mouse if not running "headless." As cheap as they are, these little things can get expensive fast if you let them.
ROCK64 2GB ~x2 cheaper  that ROCKPro64 2GB. I will use PSU and SSH. So i don't need power adapters and monitors. Only SD  multiply by SBC. Any of you have benchmark for Boinc, or Rosseta, or other perspective medicine project ?
Can some run boinc and then boinccmd --run_benchmarks. Then post pine or rock type , scoren and os?
  Pine.org very poor review rma00 9 5,145 07-07-2025, 12:06 PM
Last Post: dachalife
  Replacement international plugs for 65W GaN Pine Power Cadair 1 589 05-20-2025, 10:20 PM
  Pine Desktop PowerSupply wont power on BSharp 6 4,650 01-07-2025, 08:04 AM
Last Post: skare
  What about a Pine digital audio player? ClairelyClaire 7 5,827 12-05-2024, 09:06 PM
  pine vacuum cleaner and door phone norayr 3 2,096 01-16-2024, 02:31 AM
Last Post: hanajijang
  Android OS that supports LCD touch panel (pine a64) Spekboy 0 1,085 01-14-2024, 01:41 PM
Last Post: Spekboy
  A post about a Pine-64 Wi-Fi ethernet router project board and enclosure? Omnios 1 1,535 09-21-2023, 07:52 AM
  Is it possible to use Pine-64 board as a Mini PC such as BeeLink? Omnios 1 1,941 08-30-2023, 04:23 PM
  Possible new Pine64 product - Pine Blue Ray DVD Linux tv box Omnios 5 3,710 07-24-2023, 03:21 PM
Last Post: Omnios
  Cryptocurrency payment option and Pine hardware wallet, any thoughts? ohuw67 11 14,837 03-03-2023, 01:18 AM
Last Post: user641
