Battery and hard drive upgrades et al.
#31
All of your stated use cases the Pinebook Pro will be good enough for. You might have to get an nvme drive to have enough storage but hey.
Resist the urge to tinker with the OS, buy a USB eMMC reader just in case and you should be okay. My only concern is parts availability in 10 years time. I can still get thinkpad parts a decade on because they're manufactured in the billions but not so for the PBP.
#32
(09-16-2019, 02:20 PM)CampGareth Wrote: All of your stated use cases the Pinebook Pro will be good enough for. You might have to get an nvme drive to have enough storage but hey.
I am inclined to agree with you. I have run GIMP/Scribus/Inkscape/Audacity, Emacs, browsers et al on really modest systems and they run fine and the file sizes generated are relatively small. A machine with four gigs of RAM ought to hardly break into a sweat. Storage would be a non-issue for file sizes, except for photos. Music can be played with CMUS, which is light weight enough. Maybe something can be done with the SD slot. I am thinking about Stallman and how he used to use a LEMOTE for day-to-day computing...
  Selling my Pinebook Pro with a bootable NVMe WD SSD drive pinemouth 0 753 09-27-2023, 08:53 PM
Last Post: pinemouth
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 795 07-13-2023, 01:50 PM
Last Post: PaulQ
  Pinebook Pro drains ny battery after shutting it off Tongman 4 2,135 12-01-2022, 02:50 AM
  Battery Frost1776 1 1,052 10-07-2022, 04:17 PM
Last Post: LivingLinux
  Pinebook Pro freezes when running on battery petaramesh 5 2,556 09-22-2022, 12:43 AM
Last Post: petaramesh
Heart Now better battery life or power management? KC9UDX 5 2,288 09-09-2022, 08:13 PM
  Very low battery (but charging) causes boot failures Phillip Bell 7 4,512 02-22-2022, 11:20 AM
  high battery drain on suspend/poweroff wiz 5 5,064 02-10-2022, 11:52 AM
  Customizations or upgrades? ohuw67 4 3,970 08-23-2021, 02:09 PM
Last Post: ohuw67
  NVMe SSD and battery life? dieselnutjob 3 3,952 04-19-2021, 01:55 PM
Last Post: slyecho
