using PINEBOOK Pro M.2/NGFF NVMe SSD Interface Adapter
Hello
I would like to know why is this NVMe interface is only for pinebook pro ?  (https://store.pine64.org/?product=pinebo...ce-adapter)
I know this laptop is using a modified rockpro64 board, but what differences do they have ?
thank you
(07-26-2019, 01:51 AM)abdel Wrote: Hello
thank you
Its 40/50 pin FFC ribbon connector by the looks of it not a M.2 connector apart from that which is a huge difference identical
(07-26-2019, 01:51 AM)abdel Wrote: I would like to know why is this NVMe interface is only for pinebook pro?
As opposed to what? The original pinebook? Well, that would be simple... the A64 processor on the original pinebook doesn't support PCIe, hence no PCIe->NVMe.
I was talking about rockpro64 board.
Sorry I though this would be clear because we are in rockpro64 subforum, but I should have clarify that
I mean the pinebook pro is also using a rockpro64 board (but modified) , but I suppose stuartiannaylor is right: there is no way to connect it because no  40/50 pin FFC  connector on rockpro.
thank you guys
(07-26-2019, 04:32 AM)abdel Wrote: I was talking about rockpro64 board ... there is no way to connect it because no  40/50 pin FFC  connector on rockpro.
lol... yeah... it's nothing more than a M-keyed M.2 -> FFC ribbon connector, just like how the rockpro64 adapter is a M-keyed M.2 one, but to PCIe x4 in that instance. I've actually ordered one of these riser card extenders to see if I can mount the NVMe adapter card differently... as then I can think about putting the rockpro64 in a case... Smile
Derp: Would be a good idea to actually past the link I intended to paste in... :facepalm: ... https://www.aliexpress.com/item/33040463627.html
  ADATA XPG SX8200 Pro 2TB NVMe SSD Perf Atch 0 625 04-01-2023, 02:51 PM
Last Post: Atch
  Pad to level Emmc like the PineBook Pro JessicaQ 0 995 08-18-2022, 12:28 PM
Last Post: JessicaQ
  Full Size Bracket for the NVME PCI-E Card publiclewdness 0 1,325 12-31-2021, 12:53 AM
Last Post: publiclewdness
  PCI-E X4 to M.2/NGFF NVMe SSD - support? AndyOfLinux 22 27,878 12-13-2021, 11:04 AM
Last Post: Cerberus
  RockPro64 doesn't boot when PCIe to M.2 adapter is installed Cerberus 3 3,382 11-27-2021, 11:38 PM
Last Post: Cerberus
  zfs on rockpro64 - any dual nvme PCI adapter for software raid ? romadr 0 1,877 04-22-2021, 02:59 PM
Last Post: romadr
  case for RockPro64 + PCI-E M.2 NVMe Card? AndyOfLinux 9 12,384 01-05-2021, 05:05 PM
Last Post: kuleszdl
  UART->RS232 adapter that supports 1.5M? Skirmisher 3 5,010 08-20-2020, 03:46 PM
Last Post: foresto
  Enable I2C to interface with PCA9685 Stoovurt 0 1,643 07-14-2020, 02:13 PM
Last Post: Stoovurt
  PCI-e to Dual SATA-II Interface Card only works with one disk taube 4 4,394 12-27-2019, 10:42 AM
Last Post: taube
