RockPro64 pcie Gpu
Hey Guys,
 I have a qestion to the RockPro64. Is a nvidia 570 geforce compatible withe the RockPro64 ?
 I like to operate over the Pcie. What kind of Pcie I need (sometimes a Pcie x4 to Pcie x16 bridge) ?
 Did I need a special driver or a normal ARM64 driver. My other AMD GPU does not work. The Fans working normal but I get no signal from the HDMI port of the GPU.
I hope someone can hell me thanks  Big Grin
PC graphic cards have some x86 code that is called by the BIOS to early initialize the card so you can see text while booting. Of course this will not be available on non-x86 platforms. If the Xorg driver can initialize the card it may work, but you need it to be compiled for ARM (nouveau?). And you should make sure that the card is correctly detected. I could not use a SATA controller (LSI 9211-8i) until a hack named "pcie_rk_bus_scan_delay" was added to the kernel. You only need a riser/extender if you suspect that the Rockpro64 is not being able to supply enough current.
  where to get debian 12 image for rockpro64? heocb 1 2,375 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 2,013 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 3,226 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 2,829 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 3,971 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 3,095 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 9,963 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 3,277 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 4,278 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 5,700 03-19-2023, 06:22 AM
Last Post: runyor
