Pinebook micro USB power input mod
Decided to add a micro usb port for charging.
[Image: attachment.php?aid=1337]
[Image: attachment.php?aid=1338]
[Image: attachment.php?aid=1339]
[Image: attachment.php?aid=1340]
[Image: attachment.php?aid=1341]
EDIT: Not sure how to have the attachments display inline, not as links.
EDIT 2: Used attachment as inline images.
.jpg   DSC08482 (Medium).jpg (Size: 188.22 KB / Downloads: 877)
.jpg   DSC08484 (Medium).jpg (Size: 322.66 KB / Downloads: 1,034)
.jpg   DSC08494 (Medium).jpg (Size: 123.53 KB / Downloads: 1,014)
.jpg   DSC08497 (Medium).jpg (Size: 166.22 KB / Downloads: 1,031)
.jpg   DSC08506 (Medium).jpg (Size: 213.96 KB / Downloads: 961)
Wow. Kudos on your skills. Is there an instruction manual, how to do this? That would be awesome.
I would like to ask also another question. Not about your project, but a related question.
On page http://linux-sunxi.org/Pine_Pinebook#Pin...6.22_1080p
there is an statement in Power Managment paragraph: "There is a secondary power path via the OTG-USB port...".
Does that mean, the pinebook can be charged via the OTG-USB port? If yes, which one is it?
Thanks.
Thanks!
No instruction manual. Can provide if other members are interested as well.
I've made similar modifications to other devices before. Just went by my own experience.
Scoped out a good spot inside the pinebook with an unused threaded insert.
Cut out the necessary hole and edges from the plastic shell/panel to expose/accommodate the micro USB.
Probed the board for the 5V and GND connections to the barrel jack.
Soldered wires connecting the barrel jack connections to the micro USB breakout.
I didn't use a diode but it would help to prevent reverse voltage when both the barrel jack and micro USB are powered by different sources.
As for the OTG-USB. I found four closely situated pads near the WiFi chip on the motherboard but I'm not sure if those are the OTG-USB ones. I did not use the OTG-USB connections for this mod. If they are readily accessible, it may be the better option as opposed to connecting to the barrel jack.
As far as first posts go, this certainly takes the prize. Also, pretty sweet mod - this is exactly the sort of tinkering that was envisioned for the Pinebook in the first place.
[edit] for the pictures, in the future, I recommend just using imgur embed.
Luckily the current generation Pinebook has a plastic enclosure. Sounds like the magnesium chassis of the Pinebook Pro might not lend to these kinds of mods as readily but still looking forward to it!
  Dead Pinebook - fix it or spare parts? oloturia 2 5,460 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 3,450 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 4,420 01-05-2023, 10:42 AM
Last Post: jezek
  Pinebook Users are a nobody leperotero 13 22,375 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 3,070 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 3,712 03-08-2022, 10:14 AM
Last Post: frank-zappa
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 11,952 08-18-2021, 11:01 PM
Last Post: Corkonian
  new pinebook help ron_burgundy 5 12,112 12-17-2020, 04:54 PM
Last Post: ron_burgundy
  Few questions about flashing to a MicroSD card on the Pinebook Pro SanjevR 6 14,872 12-07-2020, 04:02 PM
Last Post: SanjevR
  TOR Browser on the Pinebook Pro jay3gg 0 4,973 11-16-2020, 01:25 AM
Last Post: jay3gg
