Dual monitor (LCD + HDMI) with Android
Is it possible to use the provided LCD TOUCH monitor AND (at the same time) an HDMI monitor?
Furthermore, if attaching an external mouse/keyboard, will it work if the touch is enabled to have dual control?
(03-21-2019, 12:15 AM)saviod Wrote: Is it possible to use the provided LCD TOUCH monitor AND (at the same time) an HDMI monitor?
The current 7" LCD panel can work together with HDMI under stock Android OS. By right should be enabled to have dual control.
Thanks for you reply!
How can i do it?
  Slash TV Android for RockPro64 Wizzard 3 1,370 08-18-2021, 12:36 AM
Last Post: scanfff
  HDMI out? scanfff 0 159 08-13-2021, 10:47 PM
Last Post: scanfff
  Install Playstore on Android 8.1.0 Domo 14 13,377 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 7,199 04-16-2021, 02:10 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 1,125 04-16-2021, 02:03 AM
Last Post: Wizzard
  Install Playstore on Android 9 image ddimension 18 12,177 02-13-2021, 12:52 AM
Last Post: chisteven
  RockPro64 line out/headphones in Android 9 Wizzard 0 1,327 11-20-2020, 04:15 AM
Last Post: Wizzard
  Android 9 drivers Firesped 1 1,956 11-19-2020, 12:39 PM
Last Post: Wizzard
  I2C on Android? ameridroid 0 1,399 03-02-2020, 03:41 PM
Last Post: ameridroid
  How to create the img file to use with etcher once you build the android SDK? dazza5000 8 4,955 01-22-2020, 10:26 AM
Last Post: webgourou
