RockPro64 with OpenMediaVault - Ethernet card is not recognized
Sad
Hello guys,
I'm having a lot of problems with the RockPro64 card.
Need help! I think I'm doing something wrong because the system goes up without recognizing the network card and some OpenMediaVault modules.
1) I am using the version of the 4Gb card;
2) I'm using a 64Gb eMMC;
3) I always use the balenaEtcher for system flash;
4) I've tried several summers of OpenMediaVault:
     Examples of the most common:
    a) -> http://wiki.pine64.org/index.php/ROCKPro...MediaVault
    b) -> https://sourceforge.net/projects/openmed...les/4.1.3/
Error:
[Image: KvtHQz1.jpg]
I believe that the card does not present problems, because the version of Ubuntu 18.04 Bionic usually works with all the components, recognizing the network card and other peripherals.
I have the error message too.
Load your image from here. > ayufan-rock64/linux-build >latest for armhf stretch-openmediavault-rockpro64-0.8.0rc8-1116-armhf.img.xz
(04-07-2019, 04:53 AM)Neo2018 Wrote: I have the error message too.
Would you care to share your experience on how the RockPro64 NAS build performs? Is it stable and reliable?
How about its power consumption, speed, efficiency?
Do you think there’s enough horsepower to run a series of plugins as Transmission, Plex, Owncloud, Domoticz, Pi-hole and Ubiquiti controller at the same time?
There is. However streaming from Plex server will (depending on the format) put considerable strain on the SOC.
Good. I guess the jury's still out until I receive my parts and assemble it. Plex is not a primary need anyway and if I set it up eventually it's going to serve one stream at a time. The other plugins are however.
I already placed my order yesterday but have not received any shipping info as of now. As it's been years since I backed my original Pine64 boards, do you by any chance know if I'm going to receive any tracking or shipping info any time soon or should I just wait until they show up one morning at my doorstep? Smile
Does OMV have a Nextcloud plugin? I had to install it alongside OMV ... was a bit of a pain from what I remember.
(04-18-2019, 07:33 AM)Luke Wrote: Does OMV have a Nextcloud plugin? I had to install it alongside OMV ... was a bit of a pain from what I remember.
Nextcloud , Owncloud, either way I'll be happy.
I wasn't 'stating', I was genuinely asking if there is a *[foss]cloud plugin for OMV (?)
I'm not sure, however I'm under the impression there's one of the 2 available as a plugin.
  where to get debian 12 image for rockpro64? heocb 1 555 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 409 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 1,255 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 1,158 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 1,865 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 1,369 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 6,761 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 1,614 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 2,413 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 3,506 03-19-2023, 06:22 AM
Last Post: runyor
