Manjaro ARM for Pinebook
Manjaro ARM website
Download here
At the moment to write this post are two versions available, see on latest post of this thread to find new updates.
KDE
[Image: 8c6138268589e267b35d122896a9642d4a9c0ef7.png]
LXQT
[Image: 475945e90d1b8185f883a4f4200ae39ac03083b8.png]
User Password
root root
manjaro manjaro
Features:
The Pinebook is a $99 laptop, based on the popular Pine64 ARM board. It sports a quad core ARM CPU, 2 GB RAM, 16 GB eMMC, Wifi and Bluetooth and either a 14" TN screen or an 11" IPS screen.
The Manjaro ARM images are marking Manjaro ARM’s first venture into ARM based laptops and is heavily based on the Arch Linux builds from user anarsoul on Github.
How to install:
Download the image/zip file from the download location. Verify that the download completed successfully.
After that, install Etcher and burn it to an SD card (8 GB or larger recommended).
Put the SD card into the Pinebooks SD card slot and boot it up. The Pinebook should recognize the SD card as a bootable device and boot from it.
The Pinebook will reboot once before it gets to a login screen. This is because the filesystem gets resized to fit the SD card.
On first boot, the wifi card gets activated after a couple of minutes, even though the tray icon (on plasma) does not change.
The zip is broken at the moment.
I strongly suggest trying out the LXQT image - its a really good preview (minor issues with sound, etc.,)
It"s good to know, is it suitable for 1080p and is it kernel 4.19.
Added Manjaro ARM (1080P Pinebook) preview2 on Wiki and PINE64 Installer.
(11-17-2018, 11:54 PM)bvbfan Wrote: It"s good to know, is it suitable for 1080p and is it kernel 4.19.
Yes, and yes  Smile
A64, SOPINE, Rock64, RockPro64, Pinebook1080p, Pinebook Pro, Pinephone, Pinewatch dev kit, Pinetab, Pinecil, Pinenut, Quartz64, Pinephone Pro, and PineNote (so far)
It works on both 1080p and standard Pinebook.
Works fine for me. Though I have not tested Wifi on battery yet.
What is the change in preview2 ?
(11-19-2018, 04:28 PM)Surehand53 Wrote: Works fine for me. Though I have not tested Wifi on battery yet.
Preview 2 is lxqt.
I will test it when it's final, NEON works well, since only in the browser does not have acceleration.
I have used the preview2 release now the whole afternoon (Europe) with battery and have not had one drop of the wifi that I would have noticed.
Works super
Small niggles:
- locale not completely set, trizen (perl) complains about that but works
- the keyboard layout is not adjusted to the somewhat unusual Pinebook layout yet but for the MENU key the tips in the Wiki-FAQ work
I am quite happy with this already
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 2 726 05-26-2025, 11:01 AM
  DietPi OS for Pinebook MichaIng 3 8,824 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 78,904 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 2,300 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 1,705 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 8,071 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 4,401 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 5,727 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 6,770 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 4,812 01-20-2021, 11:18 AM
