Feature Complete Debian Desktop Release
(05-24-2019, 02:54 AM)Slam Wrote: So far I only faced that when going to settings yes: chrome://settings/
it does load but then a second or two after it loaded I get the Aw, snap, something went wrong
Ah yes, looks like its a known issue actually (when using acceleration on this version of chromium). OK, thanks for letting us know.
@Mrfixit2001 @Luke
I have been trying to compile your new source code all day using your own debian image to compile I get errors like this (These happen during cross compile as well):
In file included from include/linux/linkage.h:6:0,
                 from include/linux/kernel.h:6,
                 from include/asm-generic/bug.h:13,
                 from ./arch/arm64/include/asm/bug.h:67,
                 from include/linux/bug.h:4,
                 from ./arch/arm64/include/asm/cmpxchg.h:21,
                 from ./arch/arm64/include/asm/atomic.h:41,
                 from include/linux/atomic.h:4,
                 from include/linux/dcache.h:4,
                 from security/security.c:15:
include/linux/export.h:59:20: error: redefinition of ‘__kstrtab_security_path_chown’
  static const char __kstrtab_##sym[]   \
include/linux/export.h:72:2: note: in expansion of macro ‘__EXPORT_SYMBOL’
  __EXPORT_SYMBOL(sym, "_gpl")
security/security.c:529:1: note: in expansion of macro ‘EXPORT_SYMBOL_GPL’
 EXPORT_SYMBOL_GPL(security_path_chown);
include/linux/export.h:59:20: note: previous definition of ‘__kstrtab_security_path_chown’ was here
include/linux/export.h:69:2: note: in expansion of macro ‘__EXPORT_SYMBOL’
  __EXPORT_SYMBOL(sym, "")
security/security.c:506:1: note: in expansion of macro ‘EXPORT_SYMBOL’
 EXPORT_SYMBOL(security_path_chown);
include/linux/export.h:63:39: error: redefinition of ‘__ksymtab_security_path_chown’
  __visible const struct kernel_symbol __ksymtab_##sym \
include/linux/export.h:63:39: note: previous definition of ‘__ksymtab_security_path_chown’ was here
make[2]: *** [scripts/Makefile.build:277: security/security.o] Error 1
I did manage to get the kernel built / compiled using the armbian image BUT with a PCIE card in the PCIE slot I get kernel panics with the new dtb file and the system refuses to boot on first boot after power on but when / if it does boot the pcie card is not found. I am attaching a dmesg of the board booted with a pcie card in the slot. I am currently rebuilding the kernel with the previous rockpro64.dts to see if it works.
Edit:
Rockpro crashed before compile finished still seems unstable and unusable.
Edit 2:
The kernel source is also missing the dptx.bin file which causes another error later in the compile.
.txt   dmesg.txt (Size: 80.46 KB / Downloads: 252)
AWSOME !!!!! Well done guys this is amazing ,,,,, fantastic work .... really pleased .... i'm going to test NvME PCIe + BlueTooth Wifi module now.
Again thanks so much for your hard work on this ... its really appreciated 1st time in 6 months I have not been able to crash the desktop within 10min.
Even audio works :-)
this means a lot to me thanks :-)
On Youtube and Netflix, video strutters a lot with 1080p, is there anything that can be done (CPU governator is in performance mod (pretending nothing, i know it is a community build, only asking)?
Apart from that, is it possible in this distro to make something similar (in a simple way): https://www.hackster.io/austin-stanton/c...irc-2fd581, using LIRC to send and receive IR command through GPIO (i have 2 pin diodes, on chip there are 3 pin slots for IR receiver, ((only receiver?)))?
By the way, really well done, a nice and useable distro!!!
Heart
Dam .... sorry to break it to you guys ,,,,, the PCIe NVMe problem causing the Desktop to hang when logging in as a non root user (strangely when you log inas root it works although chromium wont launch) is still there just like it is in Armbian
#backtosquareone
I have not even connected the BlueTooth\WiFi Dongle yet
But I am still deleteriously happy .... I can at least get Eclipse working in Debian so I can start developing more efficiently  Heart Heart Heart
@Luke did you ever get a fix for the NVMe Desktop hang ? I believe you mentioned that it was associated with the Audio Drivers ? I can not remember if you fixed it by using pulse audio or Alsa ?
Thx
Simon
(05-25-2019, 07:16 AM)torxT10 Wrote: On Youtube and Netflix, video strutters a lot with 1080p, is there anything that can be done (CPU governator is in performance mod (pretending nothing, i know it is a community build, only asking)?
Watch Netflix and youtube on the Root desktop. more fluent and undistorted.
(05-25-2019, 03:06 PM)axelf Wrote: Dam .... sorry to break it to you guys ,,,,, the PCIe NVMe problem causing the Desktop to hang when logging in as a non root user (strangely when you log inas root it works although chromium wont launch) is still there just like it is in Armbian
#backtosquareone
Thx
Simon
Working on it (mostly on, sometimes off) for months now... nope, issue not solved.
https://github.com/mrfixit2001/debian_de...tag/190527
PCIe issues have been resolved! Smile
Will test tonight. Thank you for this great update!
Excellent. Updated kernel source? So I can build and test to see if my issue is fixed.
I tried just copying the compiled dtb from your image to my rockpro but that didn't help. Maybe a recompile with the modules I need will?
Edit 1:
@Mrfixit2001
I tried rebuilding the kernel source with the modules I need for my dvb pcie card and your kernel still refuses to boot with anything connected to the pcie. I have tried 3 different dvb cards and a basic nic and I just get kernel panics and it eventually reboots.
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 17,447 08-16-2023, 01:34 AM
Last Post: varac
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 560 04-23-2023, 11:02 PM
Last Post: Thisone
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 1,349 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Armbian 22.02 Release Announcement TRS-80 0 1,158 02-28-2022, 05:08 PM
Last Post: TRS-80
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 2,424 02-19-2022, 06:44 AM
Last Post: sigmaris
  Debian image configured for USB-C OTG? djonathan 2 2,586 01-06-2022, 03:09 AM
Last Post: susy1075
Bug Unreliable display in Armbian and Debian ksattic 3 3,165 11-17-2021, 05:42 AM
Last Post: PakoSt
  Debian Bullseye & RockPro64: No tty consoles? Pete Tandy 9 7,541 11-08-2021, 02:33 PM
Last Post: TRS-80
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 1,887 10-29-2021, 11:15 AM
Last Post: TRS-80
  Two Questions About Debian on RockPro64 publiclewdness 0 1,314 09-30-2021, 11:54 AM
Last Post: publiclewdness
