Feature Complete Debian Desktop Release
Great news. Is there any ETA on when this new kernel source will be available?
I'm trying to use my rockpro as a TvHeadend server but I think the pcie keeps locking up (stream freezes randomly but after a stop and start it plays again until the next random freeze) with your previous kernel source. And I need to compile in some other dvb modules for my pcie tuner.
At the moment the only use I can get out of my rockpro is as an expensive paperweight.
(05-18-2019, 03:32 PM)Mrfixit2001 Wrote: Updated release! Still working on PCIe + Pulse issue, but in the meantime here's a bunch of goodies and updates:
https://github.com/mrfixit2001/debian_de...tag/190518
- Netflix and Spotify now play in Chromium
- Suspend and Resume support is now included
- AUFS drivers embedded into kernel
- CDN-DP firmware loading fixed
- LOTS of additional mainline back-ports and custom fixes
- Additional drivers included in kernel, including (but not limited to):
  •     - LOTS of networking stuff, such as VLAN and IPv6
  •     - Requirements for DOCKER containers
  •     - Additional Intel PCIe drivers
  •     - RAID support
- Additional PCIe driver fixes - Gen2 training now works
- Improved Networking Performance
- IR-Receiver support added to device tree
Debian 9 (Stretch) MrFixIt 190518
SBC: RockPro64 v2.1
1. Flashed [xz] image to uSD with Etcher.
OK. Verified.
2. Re-sized /ROOT partition to 59Gb, 159Mb unused.
/BOOT partition flags OK; boot, lba.
3. Booted my RKP64 with the 190518 image.
Nothing, screen stays blank, white LED double flash.
Let the RKP64 run for 5min, nothing...
4. Un-compressed 190518 image.
Re-flashed using etcher.
5. Booted my RKP64 with the 190518 image.
This image will not boot.
Can you provide the sha256 sum for the image?
I will try downloading once again and attempt to boot the image.
/Faradn
UPDATE:
2nd image download/flash/boot worked fine.
However...
Ethernet interface eth0 does not automatically initialize.
I have to disconnect/reconnect eth0 for IP connectivity.
Not good for NoMachine remote access.
/Faradn
Is there anyway to setup remote desktop connection via ssh on this build ?
Because I tried all guids out there and I could not .. I keep getting an error one way or another.
Also, do I need a driver for DSI connection ? I have the lcd screen connected via DSI but it isn't working. The HDMI work Though
Faradn - I've seen the IP connectivity reported from time to time, but it seems to always be resolved with a reboot. If you have any more details or suggestions, I encourage them! Thanks!
AmroIb - DSI and EDP are not currently enabled by default. You'll need to go about doing a kernel device tree overlay to enable them - not something I currently can reliably support, but is definitely possible.
pbut5 - will definitely update kernel source as time allows
crashes when I open the chromium settings tab.
(05-21-2019, 12:50 PM)kardanadm Wrote: crashes when I open the chromium settings tab.
I have an issue with chromium settings but not a "crash": The page load and after 1-3 seconds it change to "o snap something went wrong".
I could change a setting by being supper fast and clicking it but I didn't manage to change the other settings.
(05-21-2019, 12:32 PM)Mrfixit2001 Wrote: Faradn - I've seen the IP connectivity reported from time to time, but it seems to always be resolved with a reboot. If you have any more details or suggestions, I encourage them! Thanks!
@Mrfixit2001
I Tried disabling NetworkManager and use the/etc/network/interfaces // ifup ifdown method and
the same thing: eth0 does not auto initialize.
Now my thoughts are what's to be with the PineBookPro64...
NetworkManager will be a must since there  will be many different
wireless & wired network connections required by  the users.
I hope this will be tops on the Debian 9 bug list.
/Faradn
PS: Nice BBS makeover Wink
Unable to recreate. Is this something that only happens on the settings page for you guys?
So far I only faced that when going to settings yes: chrome://settings/
it does load but then a second or two after it loaded I get the Aw, snap, something went wrong
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,459 08-16-2023, 01:34 AM
Last Post: varac
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 2,163 04-23-2023, 11:02 PM
Last Post: Thisone
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 2,820 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Armbian 22.02 Release Announcement TRS-80 0 2,224 02-28-2022, 05:08 PM
Last Post: TRS-80
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 4,549 02-19-2022, 06:44 AM
Last Post: sigmaris
  Debian image configured for USB-C OTG? djonathan 2 4,603 01-06-2022, 03:09 AM
Last Post: susy1075
Bug Unreliable display in Armbian and Debian ksattic 3 5,461 11-17-2021, 05:42 AM
Last Post: PakoSt
  Debian Bullseye & RockPro64: No tty consoles? Pete Tandy 9 13,046 11-08-2021, 02:33 PM
Last Post: TRS-80
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 3,417 10-29-2021, 11:15 AM
Last Post: TRS-80
  Two Questions About Debian on RockPro64 publiclewdness 0 2,147 09-30-2021, 11:54 AM
Last Post: publiclewdness
