04-18-2019, 02:56 PM
Has anyone had any success mounting a SMB share for ROMS?
RETRO-GAMING: UPDATED RELEASE OF RECALBOX FOR THE ROCK64
04-29-2019, 08:37 PM
(04-18-2019, 03:02 PM)Luke Wrote:(04-18-2019, 02:56 PM)swanee3d Wrote: Has anyone had any success mounting a SMB share for ROMS? Hi sorry for the delay I wanted to poke around some more to make sure I wasn't missing something. I can't seem to get any of the methods of mounting a smb network share to work on the rock64 image but have tested them on the latest recalbox image with a pi3b and they work fine there. I tried both manually mounting from the command line and the way outlined on the github of editing the /boot/recalbox-boot.conf. If I try to manually mount from ssh I am getting this error in the /tmp/mountNetwork.err file Code: mount error: cifs filesystem not supported by the system mount -t cifs //192.168.1.xx/recalbox /mnt -o user=recalbox,password=PASSWORD,uid=0,gid=0,rw Adding shares in kodi through the ui seems to work fine.
04-30-2019, 01:55 PM
Greeting.....
can anyone tell me how to install retroarch or retropine on pineA64?
07-13-2019, 01:20 PM
(07-08-2019, 06:58 AM)Wizzard Wrote: Is anybody able to mount remote SMB shared folder from Recalbox? As far as I could figure out the newer builds are missing cifs support but NFS works. The original build and the recent official pi versions work as expected so I believe it's a build error.
07-15-2019, 02:54 AM
Ok, so this could be an issue. @Mrfixit2001 , can you please build the next build with CIFS support? Thanks!
07-20-2019, 02:03 PM
Seems that CIFS support is still not present.
