RETRO-GAMING: UPDATED RELEASE OF RECALBOX FOR THE ROCK64
Has anyone had any success mounting a SMB share for ROMS?
(04-18-2019, 02:56 PM)swanee3d Wrote: Has anyone had any success mounting a SMB share for ROMS?
Never had an issue. Whats the problem?
Hi sorry for the delay I wanted to poke around some more to make sure I wasn't missing something.
I can't seem to get any of the methods of mounting a smb network share to work on the rock64 image but have tested them on the latest recalbox image with a pi3b and they work fine there.
I tried both  manually mounting from the command line and the way outlined on the github of editing the  /boot/recalbox-boot.conf.
If I try to manually mount from ssh I am getting this error in the /tmp/mountNetwork.err file
mount error: cifs filesystem not supported by the system
mount error(19): No such device
Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
This is the manual command I used on both platforms
mount -t cifs //192.168.1.xx/recalbox  /mnt -o user=recalbox,password=PASSWORD,uid=0,gid=0,rw
Adding shares in kodi through the ui seems to work fine.
Greeting.....
can anyone tell me how to install retroarch or retropine on pineA64?
Is anybody able to mount remote SMB shared folder from Recalbox?
NOT talking about the access to internal Recalbox shared folder from another computer.
edit: I see that @swanee3d had the same problem.
@Luke , does it work for you? How do you do that?
(07-08-2019, 06:58 AM)Wizzard Wrote: Is anybody able to mount remote SMB shared folder from Recalbox?
As far as I could figure out the newer builds are missing cifs support but NFS works. The original build and the recent official pi versions work as expected so I believe it's a build error.
Ok, so this could be an issue. @Mrfixit2001 , can you please build the next build with CIFS support? Thanks!
New images are now available
Seems that CIFS support is still not present.
Updated Recalbox ver 190719 on Wiki and Pine64 Installer
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 137 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,333 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 325 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 600 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 600 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,281 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 189,771 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 584 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 640 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,046 12-07-2022, 08:22 PM
Last Post: luminosity7
