Pinebook Pro?
#51
I want one with Linux Mint. Ubuntu supports ARMv8, it should not be that hard to pull from mint repos.
#52
(02-05-2019, 04:38 PM)locoturko Wrote: I want one with Linux Mint. Ubuntu supports ARMv8, it should not be that hard to pull from mint repos.
I just checked and there is no arm64 packages for mint binaries...
http://packages.linuxmint.com/list.php?release=Tessa
#53
As a Mint user myself, I am going to guess that Mint has source packages as well, right?
If so, it should be possible to just build each required package from source?
I would love it if the Mint team had build's for Pinebook/Pinebook Pro, Ubuntu MATE would be nice, having Arch would also be a real treat.
#54
(02-05-2019, 07:27 PM)mzs.112000 Wrote: As a Mint user myself, I am going to guess that Mint has source packages as well, right?
Just pointing out that it's not as simple as just pointing apt at a new repository.
In the case of arm boards it's even messier because there is no bios to hook into for driving hardware, which why there is so many armbian images.
#55
I wonder why no one has came up with a standardized EFI system for ARM boards?
There needs to be an EFI firmware with ports for the major ARM systems, ideally it should also have a user-acessible UI just like a regular computer/laptop. Then, that would eliminate the issue of having so many images for different boards or different board variants, since the EFI would provide a standardized HAL for OS to hook into.... Installing new OS on an ARM-based laptop, SBC or PC would be as simple as installing one on an Intel computer.
#56
Stabbing in the dark, but I think it's because ARM is mostly used in embedded systems, and has only recently began being adopted into other purposes. It weren't too long ago that PowerPC was a growing contender in the server market (and briefly Apple devices), then disappeared.
Will the PineTab adopt the same SD-Card preferential boot? Personally prefer this approach, makes distrohopping really easy.
[ PHP Developer | Pinebook 1G | About me ]
#57
(02-06-2019, 03:24 PM)soupbowl Wrote: Stabbing in the dark, but I think it's because ARM is mostly used in embedded systems, and has only recently began being adopted into other purposes. It weren't too long ago that PowerPC was a growing contender in the server market (and briefly Apple devices), then disappeared.
Maybe they can use LibreBoot and Coreboot?
https://www.coreboot.org/
https://libreboot.org/
Either one would make things way easier for Linux and BSD distros to support ARM devices and PCs.
#58
I'm here because of the PCMag article, and others. I have been waiting for something like the pinebook pro for a long, long time. Kudos to you folks for achieving what has apparently been impossible for other companies! I eagerly await the moment I can get my hands on one and get to the precious bits inside!
#59
Also eagerly awaiting the Pro. Heard about it from the same articles that are floating around. Very interested in a great combination of price and performance lab machine built for linux from the ground up. Following thread for updates.
#60
You wouldn't be able to accelerate cinnamon (at least currently) so it would have to be mate edition.
  Updated Pinebook Pro? tantamount 2 1,612 06-20-2026, 10:14 AM
Last Post: tantamount
  Pinebook pro bricked? michaelmoua 4 7,213 05-26-2026, 02:20 AM
Last Post: Anthona
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 1,355 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 2,592 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 6,057 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 9,748 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 1,548 11-08-2025, 09:22 AM
Last Post: rfm83
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 8,282 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 4,802 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 28,508 03-09-2025, 11:17 AM
Last Post: davisthomas
Users browsing this thread: 10 Guest(s)
