[Jan 14] KDE Neon (20190113-1500) - Pinebook1080P / Pinebook |[Jan 14] Q4OS (2.7-r1) - Pinebook1080P / Pinebook | [Dec 07] DietPi(v6.18) - Pinebook / Manjaro KDE (preview3) / Manjaro LXQT (preview3) - Pinebook |[Dec 06] Armbian Debian Stretch (5.67) / Armbian Ubuntu 18.04 Bionic Desktop (5.67) - RockPro64 |[Dec 05] DietPi(v6.18) - 1080P Pinebook
Project Inspiration | Get Started | IRC Logs | Forum Rules/Policy
Lightest Weight OS for PB
(12-09-2018, 10:04 AM)Surehand53 Wrote: I tried DietPi yesterday as well. It worked.
I had to create the SD card twice though. The second time was successful. I have dd'ed the image.
Also every now and then the boot process fails and I end up with the final message that Ethernet could not be started. I think the actual reason is a different one but I have not checked as most times a power off/on solved it.
DietPi only needs 170M memory at startup incl LXDE and feels quite responsive. Definately a good candidate for a lightweight environment.
I booted archlinux via sd, and used that to write dietpi to the emmc. dietpi booted first try on the emmc. but failed 4-5 times after, worked once, failed several times. So dietpi doesn't like the emmc any more than the sd. Something about dietpi seems different than the other distros. Maybe it's a timing thing, I dunno. But archlinux, q4os, manjaro, and kde neon all seem to work without problem; same laptop, same sd cards, same emmc. smells like something fishy with the dietpi image to me.
