[Jan 14] KDE Neon (20190113-1500) - Pinebook1080P / Pinebook |[Jan 14] Q4OS (2.7-r1) - Pinebook1080P / Pinebook | [Dec 07] DietPi(v6.18) - Pinebook / Manjaro KDE (preview3) / Manjaro LXQT (preview3) - Pinebook |[Dec 06] Armbian Debian Stretch (5.67) / Armbian Ubuntu 18.04 Bionic Desktop (5.67) - RockPro64 |[Dec 05] DietPi(v6.18) - 1080P Pinebook
Project Inspiration | Get Started | IRC Logs | Forum Rules/Policy
Manjaro ARM for Pinebook
I'm using Preview 2 on my pinebook and all looks good.
Wifi runs over eduroam, ethernet usb dongle runs, recognize 64 gb emmc, blue function keys... all perfect.
I don't test html5 video and sound yet.
Looks very good to run over it.
I had the same experience but I do have to say that on battery the wifi drops off quite often. Sometimes it connecs right back, sometimes not.
While using the power cable that does not happen.
Appart from that it works really great.
Preview 3 is out with plenty of fixes: https://forum.manjaro.org/t/manjaro-arm-...iew3/66367
  If you manage to click this link you'll join in the IRC channel
Works great Big Grin
Updated Manjaro KDE (1080Pinebook) preview3 on Wiki and Pine64 Installer
Added Manjaro  LXQT (1080Pinebook) preview3 on Wiki and Pine64 Installer
Added Manjaro KDE (Pinebook) preview3 on Wiki and Pine64 Installer
Added Manjaro  LXQT (Pinebook) preview3 on Wiki and Pine64 Installer
Hi.
If you face problems with the Wifi connection when on battery like me then you can try a parameter for the wifi driver config file 8723cs.conf.
The parameter will turn off wifi power management.
To add the parameter you have to open 8723cs.conf with an editor of your choice and use sudo to get system access rights.
e.g.
Quote:sudo notepadqq /etc/modprobe.d/8723cs.conf
Add rtw_power_mgnt=0 at the end of the one line in that config file. In the end it should look similar to this (the MAC address will be different)
Quote:options 8723cs rtw_initmac=00:ba:ch:16:85:46 rtw_power_mgnt=0
Then save and reboot.
Since I used this change connection did not drop once.
Please test and reply if it works for you.
Also it would be interesting to know if you experience any difference in battery life when the wifi power management is turned off. So far I have not noticed a difference but there might be other experiences.
This has been the smoothest build I've tested (over KDE, DietPi, & Armbian) but I haven't managed to get HDMI output. Has anyone on here gotten it working? Any advice appreciated! In Monitor Settings my monitor is detected on HDMI-1, but I can't get it to actually display.
I installed manjaro arm KDE preview 3 on my pinebook from sd to 64 gb emmc using ethernet usb dongle.
Goes ok.
Using chromium without tweaks instead firefox goes very very good! :-P
A sample video test here
https://www.youtube.com/watch?v=g9t2_SmGUnU
Official release of Manjaro 18.12 for Pinebook. Works on both regular and 1080p Pinebooks.
erchache2000 please edit your first post so that it points to the official releases rather than the preview images, thank you!
Possibly Related Threads...
  Archlinux (mainline) for Pinebook anarsoul 44 9,857 Yesterday, 08:15 AM
Last Post: Luke
  KDE Neon Pinebook remix edition RC image bshah 61 13,710 01-14-2019, 03:20 AM
Last Post: pineadmin
  Q4OS for PINEBOOK q4osteam 82 17,599 01-14-2019, 03:17 AM
  Armbian - Xenial Desktop (Pinebook) pineadmin 77 11,803 01-12-2019, 12:41 PM
Last Post: UltraBloxX
  DietPi for Pinebook Fourdee 10 1,389 01-09-2019, 08:38 AM
Last Post: WZ9V
Information How to set the Power Off key binding in i3wm for the Pinebook MarkHaysHarris777 4 864 12-25-2018, 05:57 AM
Last Post: binholz
  Netflix on Pinebook podcastlinux 2 281 12-04-2018, 07:45 AM
Last Post: tahf
  Pinebook X11 cursor gone after updating ayufan 0.7.30 fatalhalt 0 179 12-02-2018, 10:15 PM
Last Post: fatalhalt
  Pinebook will not wake from suspend MECZero 6 276 12-02-2018, 12:17 PM
Last Post: oloturia
  How to Configure Screen Brightness in mate on pinebook via terinal? shirman 6 612 12-02-2018, 05:37 AM
Last Post: mikee3000
