How to choose kernel to boot
Hi all,
I have Rock64 2GB with Debian minimal Stretch on HDD, using the USB adapter from Pine64 shop.
System i even upgraded to buster/testing using just official Debian repo.
So far works excelent and I'm happy, except for the ancient kernel 4.14.
So here is my questions.
I plan to upgrade kernel, build it myself or wait for 4.18 from Ayufan.
But what if the new kernel will not boot, how can I recover?
Is it just possible to connect HDD to PC and change some conf file?
Another question is about HDMI.
Is it normal that I do not have output on TV (two tested) in early boot? Serial Console is needed to see SPI boot menu and his messages?
HDMI output starts workingvery late in 2-3 seconds before login.
Thanks for help for another ARM newbie?
(09-29-2018, 02:43 AM)mjd Wrote: But what if the new kernel will not boot, how can I recover?
Yes, although you'll need to have something that can modify ext4 partitions, one way to do this is running a live linux distro on your pc etc, although if you have a serial dongle you can pick from different kernels on boot
Unfortunately serial is simpler than hdmi and it kicks in long before hdmi.
I'm Linux user so ext4 is not a problemSmile
Is there any proven manual what have to do next?
I'm affraid to put my services until I ensure that rescue of the failed booting procees is possible without overwrite everything by clean image.
(09-29-2018, 05:32 AM)mjd Wrote: I'm affraid to put my services until I ensure that rescue of the failed booting procees is possible without overwrite everything by clean image.
I'm unaware of any manuals but I would install an alternate kernel and flick back and forth between them until I was happy.
And the question is, how to flick between them if I prefer to mount HDD to PC,  instead of serial console, and reconfigure.
What are the conf files where I poing out kernel of my choose.
Is there needed to execute some kind of grub-update or whatever analogical?
(09-29-2018, 07:01 AM)mjd Wrote: And the question is, how to flick between them if I prefer to mount HDD to PC,  instead of serial console, and reconfigure.
I haven't needed to do that, I just pick them on bootup from the boot menu
Quote:What are the conf files where I poing out kernel of my choose.
Most of them are on /boot or p6 partition, although the u-boot stuff is on some of the other 4 or 5 partitions
Quote:Is there needed to execute some kind of grub-update or whatever analogical?
Installing via apt or dpkg handles this.
Ok, thank you for interesting.
So far new kernel, 4.19-rc4, just works after install and for the future investigations I will buy serial console dongle.
  problem with debian emmc boot G4zCDzWb 9 879 07-30-2024, 05:41 AM
Last Post: Boia11
  Rock64 won't boot dstallmo 0 555 12-27-2023, 10:34 AM
Last Post: dstallmo
  arch rock64 does not boot nemnob 0 811 07-09-2023, 03:28 AM
Last Post: nemnob
  Disabling last mount time check on boot acwest 0 814 03-03-2023, 09:24 PM
Last Post: acwest
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 8,564 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 1,216 06-27-2022, 06:52 PM
  Linux 5.15 Kernel - openSuse mark1250 0 1,455 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 7,811 10-22-2021, 05:45 AM
Last Post: kwinz
  Setting a MAC on Rock64 U-Boot kiriakos 2 3,936 03-23-2021, 04:51 AM
Last Post: kiriakos
  Debian kernel stuck at 4.4.167 Enig123 5 6,307 12-29-2020, 12:57 PM
Last Post: kwinz
