HDMI, EDID and several other questions
since my Odroid-XU4 died, I think about switching to ROCK64.
From my experience with the XU4 I have several questions related to the GPU hardware acceleration features of the ROCK64, since I want to run some kind of Debian distribution I think that this is the right Forum to ask. (Move / Correct me if this is more related to a General Discussion on ROCK64)
Is ROCK64's able to:
  • run RetroPi, EmulationStation or Retroarch, specially how does mupen64plus perform?
  • run Kodi with ALSA or Pulseaudio with working SPDIF-Passthrough?
  • use an external USB3 Harddrive as UAS and get SAMBA performance around 80 MiB/sec?
  • force the HDMI as always connected with a custom EDID binary?
  • are there also mali-x11, mali-fbdev, kodi, kodi-fbdev packages available or how is it managed?
  • how you compile Kodi/Retroarch, any forks or patches needed?
To the EDID thing:
My Beamer is not detected if in Standby-Mode, but I need to run Kodi with Beamers EDID data...
On the XU4 I got it managed by copying EDID data from sysfs while Beamer was switched on and detected on HDMI the following way:
(See https://forum.odroid.com/viewtopic.php?f=93&t=29488 )
$ cat /sys/class/drm/card0/card0-HDMI-A-1/edid > /lib/firmware/edid/ax200e.bin
and in the u-boot's ini (/media/boot/boot.ini):
videoconfig=drm_kms_helper.edid_firmware=edid/ax200e.bin
HPD=false //forces HDMI as connected.
  HDMI doesn't work on rock64 Noung1991 1 3,350 11-21-2023, 08:33 AM
Last Post: as365n4
  armbian / bionic - hdmi to vga not functioning on newer5.4 kapqa 1 4,799 03-31-2020, 07:19 PM
  hdmi hotplug dontpostalot 2 5,395 02-08-2020, 02:40 PM
Last Post: clach04
Sad HDMI doesn't work on rock64 rock7 0 4,167 12-16-2019, 01:04 PM
Last Post: rock7
  HDMI output with Arch Linux Arm yogo1212 2 6,791 07-17-2019, 02:46 AM
Last Post: yogo1212
  Arch Linux minimal image w/ full HDMI output support hiccupstix 1 5,015 11-01-2018, 08:33 AM
Last Post: danboid
  HDMI sound on ayufan 0.7.x Trash_Can_Man 0 3,175 10-26-2018, 12:57 PM
Last Post: Trash_Can_Man
  Does the ROCK64 support CEC over HDMI? mpb 2 9,587 03-17-2018, 04:27 AM
Last Post: geno
  Couple questions about the ayufan releases Mrfixit2001 3 5,885 12-23-2017, 05:48 PM
Last Post: ClaudiaF
  Stretch Mate 4k output HDMI gladioilgatto 0 2,680 12-23-2017, 12:09 PM
Last Post: gladioilgatto
