Rockpro64 Ubuntu 18.04 minimal 64 bit - shutdown command
Unless the power supply is unplugged, the system reboots after "shutdown -h now". I just came to find out the system was powered on after a shutdown command last night. I tried the same command again. The problem is reproducible.
Edited. Following comment added: Well, on extra try to reproduce, the problem did not occur. Guess this is intermittent.
(09-14-2018, 09:07 PM)whitehat Wrote: Unless the power supply is unplugged, the system reboots after "shutdown -h now". I just came to find out the system was powered on after a shutdown command last night. I tried the same command again. The problem is reproducible.
Hello whitehat,
Could it be that you reached 70+C, and fanctl shut down for safety reasons?
Regards
all i have to say is i dont the -h flag.... i just use shutdown now...
it is a bit ambiguous... look at the man pages it states "h
Requests that the system be either halted or powered off after it has been brought down, with the choice as to which left up to the system"
so i am not sure how the choice is made but it could be the system just stays in a soft off .... like some android systems do....
here is what i looked at to get that quote...
https://linux.die.net/man/8/shutdown
Speak
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 9 16,607 10-31-2025, 06:33 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 137,097 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,077 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 3,294 01-16-2024, 10:01 AM
Last Post: Fide
  Boot/Shutdown on timer captainmorgan 8 11,386 11-01-2023, 12:08 PM
Last Post: Nikolay_Po
  Installing Ubuntu Server on RockPro64 deutschlmao 2 6,764 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 32,473 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 110,680 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 2,771 05-21-2023, 11:34 PM
Last Post: shpark
  Accidentally updated Ubuntu/ Revert possible? Thisone 0 1,394 04-19-2023, 12:03 AM
Last Post: Thisone
