How can I install tvheadend server un rock64?
Hello i am newbie , and I want install tvheadend server On my rock64 with debían
How can I do? Any tutorial?
Thanks a lot
You'll probably need to supply a little more information. Do you have the desktop version of Debian. It should be in the apt repos. Try this link to check it out https://tvheadend.org/projects/tvheadend...Repository
Thanks for your reply
Yes i have a debian with desktop version .
Yes i look this page , but i Don't Know what repository i can put for install
What version of Debian have you installed. If you have Stretch just follow the instructions for installing that version.
I have stretch , but wath i can choose
Armhf/. Arm64 ? Amd i386?
Arm64. That's the Rock64 chip.
Thanks, tren I Try this Ubuntu Xenial "xenial"
Can i change debían for ubuntu ? For try?
If you have the desktop version you should be able to install it from your Debian repo on the GUI using the GUI package installer.
(07-30-2018, 06:29 PM)Rocklobster Wrote: If you have the desktop version you should be able to install it from your Debian repo on the GUI using the GUI package installer.
What repo can i agregatte, i’m very newbiee
Assuming you are using Debian Stretch choose either Doozer or Bintray from this link https://tvheadend.org/projects/tvheadend...Repository
Just read through this link and follow the steps laid out.
Question Hardware issues with Rock64 grobbs 11 1,911 07-24-2021, 10:23 AM
Last Post: robinkyle11
  Trustzone support for Rock64 capablegh 1 155 07-17-2021, 10:15 AM
Last Post: capablegh
  Python GPIO Library for the Rock64 (R64.GPIO) Leapo 37 39,680 07-02-2021, 03:20 PM
Last Post: klausfelix
  rock64, compile problems "illegal instruction", "memory fault" -> ddr_333Mhz? klausfelix 0 146 07-02-2021, 03:13 PM
Information Serial Console for the Rock64 MarkHaysHarris777 33 31,485 06-24-2021, 12:24 PM
Last Post: mikeklien
  lost eletronic component rock64 marvin1986 1 385 06-01-2021, 06:27 PM
Last Post: 8bit
Shocked Rock64 - Reboots after few minutes addezai 2 541 04-22-2021, 07:03 PM
Last Post: addezai
  Rock64 Long Term stability ramprasad 4 2,072 03-16-2021, 07:23 PM
Last Post: Rocklobster
  Rock64 No Audio - Solved wbecks 11 15,774 03-15-2021, 03:15 PM
Last Post: lowry
  Safest way to send shutdown signal to headless Rock64 SMB server? bmurphr1 3 1,295 03-14-2021, 06:01 PM
Last Post: clach04
