[Aug 6] Debian Stretch Minimal 64bit (0.7.8) / Ubuntu 18.04 Bionic LXDE Desktop Image (0.7.8) / Ubuntu 18.04 Bionic minimal 64bit / 32bit Image (0.7.8) / Ubuntu 18.04 Bionic Containers Image (0.7.8) / Stretch OpenMediaVault OS Image armhf / Stretch OpenMediaVault OS Image arm64 ( 0.7.8) - ROCK64 | [June 25] Stock Android 8.1 - ROCK64 | [June 19] Armbian (5.42) - ROCK64 | [June 19] Armbian (5.38) - PINE A64(+) / PINE A64-LTS / SOPINE
Project Inspiration | Get Started | IRC Logs | Forum Rules/Policy
Intermittent PSU Connection
Hi all
Just received my RockPro64 and high power PSU from Pine64 shop. The PSU connection between the barrel connector on the PSU lead and the barrel connector on the RockPro64 board seems really intermittent on mine - with it proving very tricky to get the green power LED to stay on and boot to start. I have managed it a couple of times but it's really tricky.
Am I doing something obviously wrong?
Have raised a support ticket with Pine 64 - but thought I'd ask around here if there were any known issues?
(07-23-2018, 10:16 AM)noggin Wrote: Hi all
There's something wrong with the connector on the PSU or on the board, mine does exactly the same thing. Rotate the PSU barrel in the socket until the green light comes on and then *don't touch it* or you'll cut power.
High quality QA right here folks.
If there is any vertical pressure on my power connector the power is interrupted. Just a tiny amount of pressure from the tension in the cable will do this. This makes the board effectively unusable.
It's taking a while to resolve via the support ticket system, my last update with requested information remains un-answered after 5 days...
