10-11-2018, 05:04 AM
Stock Android Oreo 8.1 release
10-12-2018, 03:17 PM
(10-11-2018, 05:04 AM)AlexS Wrote:(10-09-2018, 08:31 PM)fusionneur Wrote: I tried several times flashing 8.1 with AndroidTool on EMMC, but after first reboot all I get is a black screen. 7.1.2 works fine however. Any1 managed to flash 8.1 on EMMC? (if yes, how??) I will ask QA to recheck the A8.1 on eMMC boot build.
10-29-2018, 02:46 AM
(This post was last modified: 10-29-2018, 02:49 AM by AlexS.
Edit Reason: additional question
Will there be any changes with that non-bootable oreo 8.1?
Flashing via usb2emmc adaptor makes non-usable image which boots to recovery page and that's all. rock64&4Gb And can anybody tell whether this 8.1 will support bluetooth usb probably ?
10-30-2018, 10:51 AM
Asking took too long, where is result?
11-21-2018, 05:38 AM
Please could you at least include navigation bar and status bar in the next build? Otherwise the board is absolutely unusable with a touchscreen
11-21-2018, 10:18 AM
(08-03-2018, 12:36 AM)kostaman Wrote:(08-02-2018, 11:52 AM)dougunder Wrote: I created with dd directly to usb mmc. Been a linux admin for 20years. I know what I'm doing with disk imaging, This POS lives in a drawer now, I bought a "development" board that actually works, an odroid c2. None of these problems. I will not buy another pine device.
11-25-2018, 09:31 AM
(10-12-2018, 03:17 PM)tllim Wrote:(10-11-2018, 05:04 AM)AlexS Wrote:(10-09-2018, 08:31 PM)fusionneur Wrote: I tried several times flashing 8.1 with AndroidTool on EMMC, but after first reboot all I get is a black screen. 7.1.2 works fine however. Any1 managed to flash 8.1 on EMMC? (if yes, how??) I also have the same issue that after logo is black screen 2nd option don't work : >>DD image to eMMC module. Highly recommend using Etcher [url=https://etcher.io/][/url] Etcher don't recognize the unit use this one has no issue Android 7.1.2 Stock Image [microSD to eMMC] [Rooted] [20171204] Will there be Android 8.1 [microSD to eMMC] built ? Thanks
11-25-2018, 09:34 AM
I also have same problem flashing to eMMC with option 1 - black screen after logo
Option 2 - >>DD image to eMMC module. Highly recommend using Etcher Not recognize the unit Will there be [microsd->eMMC] like android 7.1.2? Thanks a lot >>Android 7.1.2 Stock Image [microSD to eMMC] [Rooted] [20171204] Using android 7.1.2 on eMMC with this option now
08-27-2019, 09:34 PM
Has anyone got Bluetooth working on Android 8.1? Just wondering as I haven't been able to get it to work on 7.1, and I gave up on 8 momentarily due to experiencing a whole lot more slowness than in 7.1 (I'm using the 4GB Rock64, SD card).
04-11-2020, 04:43 PM
(This post was last modified: 04-11-2020, 04:55 PM by Pepe.
Edit Reason: Add link
I can confirm that Android 8.1. Stock Image [eMMC Boot] using ROCKChip tools method [20180606] worked for me. There is preinstalled Google Play Store , which is not in Android 9.x. However, when you go to Google Play Store it tells you:
Quote:This version of the app isn't compatible with your device. To fix this problem, go to Settings and uninstall updates for the Google Play Store app.Which of course, does not work. // EDIT: Downloading the latest version of Google Play Store (Android TV) as .apk worked! Unfortunately, the same does not work on Android 9.x. |
