[Aug 6] Debian Stretch Minimal 64bit (0.7.8) / Ubuntu 18.04 Bionic LXDE Desktop Image (0.7.8) / Ubuntu 18.04 Bionic minimal 64bit / 32bit Image (0.7.8) / Ubuntu 18.04 Bionic Containers Image (0.7.8) / Stretch OpenMediaVault OS Image armhf / Stretch OpenMediaVault OS Image arm64 ( 0.7.8) - ROCK64 | [June 25] Stock Android 8.1 - ROCK64 | [June 19] Armbian (5.42) - ROCK64 | [June 19] Armbian (5.38) - PINE A64(+) / PINE A64-LTS / SOPINE
Project Inspiration | Get Started | IRC Logs | Forum Rules/Policy
Android 7.1 with Navbar & Statusbar
Rainbow
Hello friends,
I would like to show you my solution for a normal Android experience here.
The firmware I use is for the Beelink A1, I mixed it up with boot.img and kernel.img from ayufan's Android 7.1 (build-115) and a TWRP-Recovery from freaktab.com Wink
[Image: #!8NpzDAJb!VnZxyfqkgu7wBlK4kqrpMynQILmyWbvKC-7RqtcAYqk]
[Image: #!xIZGWYTY!23ymk7AXNZUq7aKKPlq5xFTTvbRm3iUETA1aK6AgP1Y]
[Image: #!kQQSDACb!JLLHlU6ELrp4iLOXB_dNKg1A6-WgBN2_JWCHtPQ3NIg]
[Image: #!MVhSDBIL!bKBbm8_g9Oul7Cf-0L92Uz4s20pQPxN0sf9E7XlrTy4]
[Image: #!gZRzlTTQ!hWP2bPhSmypkU1FN4G7-LloHhD_SpjVh1rZY-ugFtqA]
Downloads:
   Beelink A1 Firmware-Files
   Kernel & Boot by Ayufan
   TWRP 3.1.1-0 from FreakTab
   AndroidTool 2.38
Installation:
   1. connect the eMMC-Modul to the ROCK64
   2. plug your USB A-to-A cable into your PC and the ROCK64
   3. hold the Recovery-Button and plug in the Power-Cable
   4. start the AndroidTool and select all the files you downloaded above, in the "Download Firmware-Section"
   5. hit the "Run-Button" and wait for reboot
PS: I use the Microsoft Launcher Wink
Unfortunately, I do not get root privileges. Maybe someone can help me with that...
Thanks for sharing this. Its a pity that the images are not showing correctly; would you mind linking one or two of them from imgur or other similar service ?
  If you manage to click this link you'll join in the IRC channel
(06-15-2018, 01:49 AM)Luke Wrote: Thanks for sharing this. Its a pity that the images are not showing correctly; would you mind linking one or two of them from imgur or other similar service ?
I dont know how to edit my post, I will learn it tommorrow Big Grin
...and then I will upload a new thread also, with a much better firmware I found Wink
Possibly Related Threads...
  Which Android version supports Google Play? AkiraSensei 0 30 11 hours ago
Last Post: AkiraSensei
  Android Images (ROCK64) pineadmin 51 19,725 08-13-2018, 09:15 PM
Last Post: ameridroid
  Stock Android Oreo 8.1 release tllim 36 5,170 08-12-2018, 06:31 AM
Last Post: AlexS
  Android Oreo 8.1 source code shinymetal 2 201 08-08-2018, 06:29 AM
Last Post: shinymetal
Wink Best Android OS - for KODI soerenderfor 2 193 07-30-2018, 07:31 AM
Last Post: soerenderfor
  wiki Android TV 7.1 file error ycllwl 3 196 07-18-2018, 07:56 AM
Last Post: ycllwl
  Bluetooth CSR8510 not working with Rock64 Android 7.1 efreeze 8 1,022 07-10-2018, 03:21 PM
Last Post: Poincare
  Installing Android on SD Card Phingum 8 585 06-25-2018, 02:47 AM
Last Post: pfeerick
  Android Security isndw 30 3,695 06-20-2018, 04:02 PM
  Compiling android kernel ddaarrius 2 216 06-13-2018, 03:26 AM
Last Post: ddaarrius
