Tor Relay How To
Hi all, the below link describes how to set up a Tor Relay on the "Pi"
Can this be done to the Pine A64(+) using a similar instruction set?
https://www.linux.com/blog/intro-to-linu...relay-node
(06-13-2018, 02:03 AM)S265 Wrote: Hi all, the below link describes how to set up a Tor Relay on the "Pi"
In short, yes. If you want an AP with TOR (and other features such as VPN) then you can also just take a look in Evilbunny's git
Thanks, will try this.
