New ROCK64 doesn't boot
Hello all:
in first place, I want to say hello to all, I'm a new user of Rock64 and this forum.
I've received my new Rock64 yesterday, and I can't get to boot never...
I've tried with a lot of images from the Pine64 installer and others burned with Etcher (ubuntu, xenial, diet, openmediavault, etc)
I've tried with two differents SD cards
I've tried with network and without it
I've tried with a usbserial connected to 6, 8 and 10 pin to monitor console output (no output received)
... and the result is always the same:
The green led is on
The red led is on
The white led is on
All permanently
And there is no output from HDMI
Someone can help me to understand what's wrong? Am I missing something?
Thanks in advance...
(06-02-2018, 05:05 AM)p3ntium Wrote: Someone can help me to understand what's wrong? Am I missing something?
Are you using a TV or Monitor?
What resolution etc?
Are you able to check what IP it gets from your router and try pinging it?
Hi:
It's a monitor Up to 1920ppp
Yes the ethernet cable is always connected and the rock64 never gets IP
Thnkss
Have you tried powering it up without the SD card inserted. What is the status of the LEDs when you do this.
Hi:
I've tested now. The result is the same:
The green led is on
The red led is on
The white led is on
All permanently
Sad
Someone can say me a stable image that works for sure. I want to test if my board can run almost one time.
I don't know if my Rock64 is broken or I'm wrong at all...
Thanks!!!
these are old but stable releases
https://github.com/ayufan-rock64/linux-b...tag/0.5.10
I've tested with a pair of these and the same result....
Always it's hard like this? I mean, I have a lot of raspberries pi 3 and all boot at first time after burn the image with etcher.
With this board (Rock64), after my experience and other posts I've read, it seems that the Rock64 is hard to get a stable boot...
It's very frustrating...
This one worked for me first time. Try it yourself and see https://www.armbian.com/rock64/
I've already tested these images. The same results:
All 3 leds on
Ethernet led on
And nothing happens: no hdmi output, no dhcp requests....
  Rock64 won't boot luminosity7 9 3,070 05-20-2023, 08:43 AM
Last Post: luminosity7
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 1,433 04-29-2023, 04:24 AM
Last Post: newestssd
  OpenWRT on the Rock64 CanadianBacon 12 6,797 04-24-2023, 12:40 PM
Last Post: arunkhan
  Rock64 board not working, no HDMI no Ethernet. EDited 3 3,047 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 1,578 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 574 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 772 10-07-2022, 07:50 PM
Last Post: rookie_267
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 853 09-18-2022, 02:29 PM
Last Post: mexicanflyer
  ROCK64 - Not start mathieu 0 1,053 07-11-2022, 03:49 AM
Last Post: mathieu
  Rock64 bricked shawwwn 6 4,995 01-29-2022, 05:49 AM
Last Post: shawwwn
