Wierd Dietpi boot/non-boot issue
Greetings all:
Hardware: Rock64 w/4GB RAM + 16GB MicroSD Card
OS: Dietpi
Issue:
When I use the recommended forked version of Etcher (running on Win 10) to flash Dietpi, I get NO video output. I even flashed it again but no video output
However, when I use Etcher (running on Arch), I get the normal Dietpi boot-up.
Why????
What is the forked version of Etcher doing (differently)?
Thanks,
Mike
(05-25-2018, 11:24 AM)miguelito Wrote: Greetings all:
OS: Dietpi
Issue:
Why????
Probably a different version, looking at the json config file it's getting this file:
http://files.pine64.org/os/ROCK64/dietpi...ch).img.xz
What version did you flash?
OS: Dietpi
Issue:
Why????
EvilBunny,
I just chose the image offered from the menu using the forked Pine64 installer:
DietPi_v145_Rock64-arm64-(Stretch).img.xz
It looks like the forked installer downloads  an older version.  Maybe the installer needs to pull only the newest images?
Anyway,  thanks for the quick reply!
Mike
(05-25-2018, 10:39 PM)miguelito Wrote: EvilBunny,
Mike
looking at version numbers, 145 is older than 156.
Also are you using a monitor or tv?
My tv sets the right resolution, but either my monitor or the dvi adaptor into it sends corrupt screen info and I have to force the resolution to be 1080p.
Evilbunny,
I used the version of Dietpi that the forked Etcher offers:
When you select Dietpi from the Etcher menu (and not select a specific download) this is the version that you get.
This explains it! Maybe the Etcher should only pull the most recent version of the images?
Thanks for the quick reply.
Regards,
Mike
Bunny,
I'm using an old (ancient) Toshiba TV/monitor. I don't think it's 1080. I think it's 720. Given that Dietpi is running ncurses (bash scripts) I would think that the default video config would be a failsafe one. I'm running the Rock64 headless so after the initial config, I'm only using SSH.
Mike
(05-26-2018, 08:05 AM)miguelito Wrote: Evilbunny,
Regards,
Mike
I don't know why it's pulling that version, because the config file points to the link I posted above. v156.
http://files.pine64.org/sw/pine64_instal...ock64.json
(05-26-2018, 08:09 AM)miguelito Wrote: Bunny,
Mike
So long as it works is the main thing.
(05-25-2018, 10:39 PM)miguelito Wrote: DietPi_v145_Rock64-arm64-(Stretch).img.xz
I just installed the installer and the only way v145 shows up is if you select the pine64 board, if you select the rock64 board it shows v156
  How to boot an older, working kernel bits 0 724 11-01-2024, 04:43 PM
Last Post: bits
  problem with debian emmc boot G4zCDzWb 10 5,122 11-01-2024, 04:32 PM
Last Post: bits
  arch rock64 does not boot nemnob 1 1,692 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 57,361 09-01-2024, 06:43 AM
Last Post: RaymondDay
  Rock64 won't boot dstallmo 0 1,123 12-27-2023, 10:34 AM
Last Post: dstallmo
  Disabling last mount time check on boot acwest 0 1,344 03-03-2023, 09:24 PM
Last Post: acwest
  USB3.0 Issues at DietPi(Armbian) #22.02.1 t4_4t 3 3,804 08-15-2022, 06:58 PM
Last Post: TRS-80
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 10,301 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 1,892 06-27-2022, 06:52 PM
  Setting a MAC on Rock64 U-Boot kiriakos 2 5,039 03-23-2021, 04:51 AM
Last Post: kiriakos
