[May 21] Slackware (20180508) ROCK64 | [May 18] NextCloudPi (2018_05_10) ROCK64 | [April 06] Volumio (2.390-2018-03-27) ROCK64 | [April 06] Q4OS (2.4-r3) PINE A64(+) Pinebook | [Jan 06] Arch Linux (20171225-1) PINE A64(+) Pinebook A64-LTS/SOPINE | [Jan 04] Linux (0.5.15-136) ROCK64 | [Jan 04] Android (20171204) ROCK64
Project Inspiration | Get Started | IRC Logs | Forum Rules/Policy
LPDDR4 Benchmarks
I'm interested in what benchmarks changed with the move from LPDDR3 to LPDDR4.
To start with, specifically what is the output of
cryptsetup benchmark
with LPDDR4?
Once there is a Linux image available I'll post benchmarks.
  If you manage to click this link you'll join in the IRC channel
Currently LPDDR4 set to PC-1600 parameter and will push up in near future. This means expects as PC-1600 type of performance result first.
Just for fun I used
termux-ubuntu
on my phone but it only got part way ;
# Tests are approximate using memory only (no storage IO).
PBKDF2-sha1       859488 iterations per second for 256-bit key
PBKDF2-sha256    1699474 iterations per second for 256-bit key
PBKDF2-sha512     497426 iterations per second for 256-bit key
PBKDF2-ripemd160  447344 iterations per second for 256-bit key
PBKDF2-whirlpool  168907 iterations per second for 256-bit key
argon2i       4 iterations, 664468 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time)
argon2id      4 iterations, 726194 memory, 4 parallel threads (CPUs) for 256-bit key (requested 2000 ms time)
Required kernel crypto interface not available.
Ensure you have algif_skcipher kernel module loaded.
other rk3399 RAM benchmarks here.
