04-30-2018, 09:54 AM
[Archived] ANNOUNCING RECALBOX FOR THE ROCK64 - ALPHA RELEASE
04-30-2018, 10:22 AM
Booted up.
Could be automated somehow
04-30-2018, 10:24 AM
Thank you very much for your work, I am downloading the image and later I will try it again. Thanks again for your time to support the rock64
No original Xbox One controller support?
Wysłane z mojego Redmi Note 4 przy użyciu Tapatalka After switching storage to disk - it sees only files crested "itself", doesn't see the rest of disk - fortunately it didn't format it. I wanted to combine it with with SMB and NFS shares so I'm playing with smb.comf I have already discovered SSH default access: root/recalboxroot As I want to use disk only as media/roms source not mounting points, it looks I'll have to play a bit to achieve proper SMB and NFS support
04-30-2018, 11:45 AM
@Mrfixit2001
Can NFS support be added? Xbox One Kodi client doesn't support SMB shares. My main goal is to use Emulators + SMB + NFS (04-30-2018, 11:45 AM)S3phi40T Wrote: @Mrfixit2001 Can it ? yes. Will it - no. The reason is, once we've got the code cleaned up it'll be passed onto Recalbox to maintain, and Recalbox only has the bits it has ... NFS is not one of them.
04-30-2018, 12:25 PM
it seems I'll get back to Ayufan's releases then.
...but I'm thinking of dualboot - Recalbox on mSD and Ayufan's builld on eMMC. Anyways, as a pure retro emulator, Recalbox seems to be nice distribution for EmulationStation.
04-30-2018, 01:35 PM
(04-30-2018, 12:25 PM)S3phi40T Wrote: it seems I'll get back to Ayufan's releases then. Hold your horses ... I may have been wrong about that. Perhaps we could add NFS to it after all. Wait for mrfixit2001 to confirm...
04-30-2018, 07:05 PM
The libraries for nfs could likely be added to the next release, but the users would have to be responsible for the configuration, since nothing in the build actually requires it. So sure, I'll have the config include libnfs for the next image and hopefully that will meet the need!
04-30-2018, 08:37 PM
Thanks for your hard work!
The two USB wifi adapters I had on hand didn't work. They show up on dmesg but their LEDs didn't light up. I'll have to grab the one from the Rock64 store I suppose. Everything else works great so far, however! |
