Ethernet Slow Download
(04-27-2016, 05:36 PM)lenny.raposo-pine64.pro Wrote: it's on one of the bug reports for the 3.10.65 BSP kernel.
Something myself and others are trying to address, but if you set the link speed to 100mbits it will atleast give you a much more stable connection for the time being until the ethernet issues get patched up Wink
thank you for the info, i cant wait until its patched up, setting link speed to 100mbit increased my speed to insane 1mbit Tongue
Same issue on arch linux... (same kernel, also)
Hoping a patch will be released soon Big Grin
(05-08-2016, 01:14 PM)malevolent Wrote: Same issue on arch linux... (same kernel, also)
Nope, different issue. There exist a few and totally unrelated Ethernet issues but nothing will change since people are encouraged to mix things up and don't get back to us with feedback (unlike you) since they're busy dealing with workarounds (switching down to Fast Ethernet instead of helping devs understand the issues some users are running into) or feeding 'bug trackers' that work like a trash can.
Since information posted into this forum is also like throwing sentences into the trash since it's not picked up to feed a real FAQ or the Pine64 wiki it's useless to waste time to explain (again).
"...instead of helping devs understand the issues some users are running into..."
I'm on longsleep's Ubuntu image. If you want to tell me what I need to type to get you the debugging information you seek, I'll gladly help.
(05-09-2016, 05:50 AM)utdrmac Wrote: "...instead of helping devs understand the issues some users are running into..."
There's nothing to type. A multimeter is needed and the willingness to not jump to the next silly workaround but provide information instead:
http://forum.pine64.org/showthread.php?tid=887&page=2 (potential relationship between underpowering and GbE Ethernet)
BTW: On Android/RemixOS if you use any of the common SD cards that show horribly low random I/O performance Android's use of the fsync call could already 'slow down networking' since writes to the card are the real bottleneck (so you suffer from blocked I/O but think it's network related): http://forum.pine64.org/showthread.php?tid=191&page=6
With Arch Linux on my 1GB A64+ I get stable speeds of ~300mbit/s downstream (to the Pine), and ~200mbit/s upstream.
With `ethtool -s eth0 speed 100 duplex full` everything is working fine. I tested 3 power supplies ranging from 2.5A to 3.5A. The only thing that I didn't try was using a shorter ethernet cable. I am using a 10m ethernet cable I might suspect that could be the culprit.
Will try a shorter cable and report here.
Just tried a shorter ethernet cable and nothing changed still utterly slow in gigabit mode. Totally fine in 100Mbit mode.
I am using a 2GB A64+ using longsleeps ubuntu image using this kernel
`Linux pine64 3.10.101-0-pine64-longsleep #39 SMP PREEMPT Sat May 7 12:39:25 CEST 2016 aarch64 aarch64 aarch64 GNU/Linux`
(05-14-2016, 11:29 AM)luggi Wrote: With `ethtool -s eth0 speed 100 duplex full` everything is working fine. I tested 3 power supplies ranging from 2.5A to 3.5A. The only thing that I didn't try was using a shorter ethernet cable. I am using a 10m ethernet cable I might suspect that could be the culprit.
What hardware make/model is on the other end of the cable. So many seem to see a issue like this maybe its a common piece of hw the pine is not connecting with properly?
How do you `ethtool -s eth0 speed 100 duplex full`.... ssh from laptop to the Pine64?
I got 2 Pine64 2gb (one running Remix OS and the other on Andriod)....Sorry, im kinda a noob to Linux environment.
(05-14-2016, 08:36 PM)rahlquist Wrote: What hardware make/model is on the other end of the cable. So many seem to see a issue like this maybe its a common piece of hw the pine is not connecting with properly?
It is a Fritz!Box.
  Ethernet port down afert 1 day jeda 0 1,783 11-12-2022, 06:48 AM
Last Post: jeda
  Ethernet --> Causing boot loop podtofs 3 7,147 05-16-2017, 03:41 AM
Last Post: m17
  GbE Ethernet Port Issue Data Gathering Statistics Intel MarkHaysHarris777 19 32,545 01-17-2017, 01:17 AM
Last Post: DrunkTank
  What will it take to get the Ethernet port working? clarkss12 10 22,235 10-17-2016, 03:42 PM
Last Post: waldo
  Pine64+ 1GB Ethernet Port spec ecotack 13 22,115 08-20-2016, 09:28 PM
Last Post: pfeerick
  If you have had difficulty with the GbE ethernet please take the poll MarkHaysHarris777 0 3,265 08-17-2016, 05:44 PM
Last Post: MarkHaysHarris777
  Ethernet works on Arch Linux. Nothing elese pfunk237 4 8,344 07-23-2016, 03:07 PM
Last Post: SuperArmySoldiers
