Rock64 Starter Kit Help
Hi, I am planning to buy Rock64 4GB, I decided to opt for this because of the better speeds than the raspberry pi.
Would you think this a good starter pack for emulation and media center purposes? What else do I need, or what I don't need?
Thanks!
[Image: R12fXbs.png]
eMMC for better speeds ? Smile
(03-21-2018, 10:25 AM)mikedhoore Wrote: eMMC for better speeds ? Smile
... and a USB ->eMMC adaptor.
How will you power the rock64. Not sure usb to power will be the best thing to do. real 5V 3A POWER SUPPLY should be the best .
If you don't have an external hdd, eMMC could be a good option.
I recommend 5V 3A power supply, pine64 remote or another airmouse/remote, and dac if you want hifi audio. If you are using wifi I recommend adding RTL8812AU dongle, so far I have found it really good!
All of the suggestions so far have been good.
Power supply - either get the one from the store, or make sure you have a good 5v @ 2A (min) USB power supply
Storage - eMMC (get the USB adapter while you're at it to make life easier) really is worth it... it will boot noticeably faster and be more responsive overall. I can't comment on the microSDs that pine64 stock, but I miss a chance to recommend Samsung EVO microSDs Wink ... they are thus far the most compatible, reliable and best-performing microSDs I have used to date, consistently so, and without costing an arm and a leg Wink
Networking - get the wifi adapter from the store as recommended if you need wifi
About eMMC: its totally worth it if your use case requires USB 3.0 and you want to maintain the small footprint. Otherwise, you could just us a run-of-the-mill USB 3.0 HDD you've got kicking around for booting via SPI.
My starter kit:
- ROCK64 MEDIA BOARD COMPUTER DRAM: 4GB (more RAM = better, especially if you copy large files)
- ROCK64 / PINE A64 / PINE H64 Heatsink (one is sufficient, could be a bigger one but heat is not the issue for Roch64)
- ROCK64 USB WIFI 802.11B/G/N (RTL8188EU) (works out of the box - good addition if you need simple wi-fi)
- ROCK64 ACRYLIC OPEN ENCLOSURE (could be better - there are other options on Amazon)
- ROCK64 / PINE H64 5V 3A INTERNATIONAL POWER SUPPLY with AU, EU, UK, US PLUG (!!must have!! as it looks as they pick the barrel that fits perfectly into your Rock's socket. I had 2 boards, swapped power supplies and the barrel was lose so I had power loses/disconnects)
- 64GB eMMC Module (size is not important if you use OVM)
- USB Adapter for eMMC Module (!!if you use eMMC it's a life saver!! makes installation easy peasy)
  Rock64 won't boot luminosity7 7 1,097 01-30-2023, 12:43 PM
Last Post: fxc
  Rock64 board not working, no HDMI no Ethernet. EDited 3 2,152 01-17-2023, 02:31 PM
Last Post: Flagtrax
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 2 558 12-16-2022, 09:51 PM
Last Post: drvlikhell
  ROCK64 v3 can it boot from USB? Tsagualsa 4 617 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 261 11-28-2022, 02:18 PM
Last Post: Macgyver
  OpenWRT on the Rock64 CanadianBacon 9 4,093 11-05-2022, 03:07 PM
Last Post: wilsonYan
  my rock64 dosen't work rookie_267 0 447 10-07-2022, 07:50 PM
Last Post: rookie_267
  Rock64 u-boot for eMMC Build Error mexicanflyer 0 501 09-18-2022, 02:29 PM
Last Post: mexicanflyer
  ROCK64 - Not start mathieu 0 706 07-11-2022, 03:49 AM
Last Post: mathieu
  Rock64 bricked shawwwn 6 3,759 01-29-2022, 05:49 AM
Last Post: shawwwn
