slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
#91
(11-23-2020, 02:12 AM)Enig123 Wrote: Thank you for your quick help. BTW, I am using the base image, and the slackpkg installed from the current branch does not work as expected somehow. It kept asking for the correct pgp key.
Perhaps I installed the wrong version of slackpkg?
Edit: Another question is for how to unzip a .zip file, which usually use package named "unzip" in most Linux distributions.
in the file /etc/slackpkg/slackpkg.conf change CHECKGPG=on to CHECKGPG=off
unzip is in the package infozip-6.0-aarch64-5.txz
donation   slarm64
Further help needed please. When I was trying to compile some c program, the following error message appears:
/usr/libexec/gcc/aarch64-slackware-linux/10.2.0/cc1: error while loading shared libraries: libisl.so.23: cannot open shared object file: No such file or directory
How can I do to fix it? I've already installed both 'd' and 'l' categories.
Edit: Even if I resolved this error by adding link to /usr/lib64/libisl.so.22.0.1, there's other similar errors coming, like libzstd.so.1, there must be something wrong with my development setup.
(11-23-2020, 02:42 PM)Enig123 Wrote: Further help needed please. When I was trying to compile some c program, the following error message appears:
the library is in l isl-0.23-aarch64-1.txz
it looks like not all packages are new.
try to do
slackpkg update
slackpkg upgrade-all
donation   slarm64
Tried it but with no success, unfortunately. The upgrade-all didn't do anything at all.
Edit: Other troubles that I've encountered, which also related to lib not found:
case 1: nslookup: error while loading shared libraries: libedit.so.0: cannot open shared object file: No such file or directory
case 2: dig: error while loading shared libraries: libjson-c.so.5: cannot open shared object file: No such file or directory
this is a bit weird when using the image.
what image did you use.
yeah, you installed bind separately, so you also need to install the library data.
donation   slarm64
(11-23-2020, 04:24 PM)mara Wrote: this is a bit weird when using the image.
The image I am using is kernel 4.4.241 base.
As I recall, I didn't install bind separately, the nslookup command is already there.
And, which library data is needed for nslookup to work?
Edit: Right now, to fix the development environment is more urgent for me.
Edit1: Just tested nslookup with the 4.9.y base image, the same error message appeared.
libedit-20191231_3.1-aarch64-1.txz
json-c-0.15_20200726-aarch64-1.txz
added packages required for bind
donation   slarm64
update:
slarm64-current-aarch64-base-rootfs-20201115-4.4.246-rock64-build-20201124.img.zst
slarm64-current-aarch64-base-rootfs-20201115-4.4.246-rock64-build-20201124.img.zst.sha256
slarm64-current-aarch64-xfce-rootfs-20201115-4.4.246-rock64-build-20201124.img.zst
slarm64-current-aarch64-xfce-rootfs-20201115-4.4.246-rock64-build-20201124.img.zst.sha256
@Enig123,
in this image I added missing libraries to nslookup.
donation   slarm64
(11-24-2020, 03:44 PM)mara Wrote: update:
@Enig123,
Thanks.
Do I have to do it from scratch or is there a way to upgrade from last version?
And, how about the development setup issue?
Edit: Well, I just tried another time to setup development environment with the new image. It's not there yet.
Not only gcc has the same shared libraries (libisl.so.23 for example) error, git also has similar error, while it showed to be libnghttp2.so.14 instead.
I will be very appreciated if you guys can fix these errors and make this already great distribution even ready-er.
(11-24-2020, 04:46 PM)Enig123 Wrote: Do I have to do it from scratch or is there a way to upgrade from last version?
using a new image, yes.
install
l/isl-0.23-aarch64-1.txz
n/nghttp2-1.41.0-aarch64-1.txz
these are not distribution errors, this is dependency management, which in this distribution lies on the shoulders of the user.
donation   slarm64
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 150 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,353 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 334 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 613 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 607 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,356 10-12-2023, 05:14 PM
Last Post: tpaul
  arch rock64 does not boot nemnob 0 591 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 650 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,305 12-07-2022, 08:22 PM
Last Post: luminosity7
  Using multiple UART's on Rock64. ramprasad 0 929 08-29-2022, 01:22 PM
Last Post: ramprasad
