Rock64 Xenial Mate Community Build Image [microSD to eMMC] [0.5.15-136]
Hi Everyone,
Okay so I a bit of a noob here and If I'm on the wrong board I apologize, Okay that being said I've purchased the rock64-4G+64gbSSD (Which I've found to be a fantastic sbc) however I'm having a few issues with the "Xenial Mate Community Build Image [microSD to eMMC] [0.5.15-136]" image I've managed to install it on my SSD which was easy (Thanks to ayufan' build),  Now going through MATE I've tried to add users and use the network function but every time I try to use it all I get is "The Configuration could not be loaded, an unknown error occured"  when trying to add users via the terminal (sudo users-admin)  I get "There was an unknown error communicating with the backends: failed to execute program org.freedesktop.SystemToolsBackends: Permission denied" is there a reason for this,  is there some sort of policy setup on this image?  Does anyone know what this means as I've said I'm a noob to this environment and starting a long learning curve.
Thanks  Big Grin
you might want to check if user-admin permissions is set to execute.
Hey, since you wan't to use a desktop environment I'd like to suggest you read this thread and use the latest 0.6.X image instead because it offers a much better desktop experience. Although 0.6.X isn't a stable image I have seen very few reports of issues with it and you'll be able to easily update to stable in the future.
I'm using the 4.4.77-rockchip-ayufan-136 Xenial build, and I also have trouble with various UI elements.  Trying to run the Users and Groups from the System>Administration menu gives:
The configuration could not be loaded
An unknown error occurred.
Running "sudo users-admin" from the command line gives the same error as Gold:
Liboobs-WARNING **: There was an unknown error communicating with the backends: Failed to execute program org.freedesktop.systemtoolsbackends permission denied
This suggests that the default rock64 account is not a member of a needed group, but I don't know what.  I know someone else that is seeing the same problem.  Luke, moving to 0.6.x isn't an option (I tried and my rock stops responding after about 1/2 hour).
Any thoughts on what group might be needed, or permissions set?
"Failed to execute program org.freedesktop.systemtoolsbackends permission denied."
I confirmed about.
The environment is the state where all "UpDate" as of today are applied to the following images.
https://github.com/ayufan-rock64/linux-b...tag/0.5.15
xenial-mate-rock64-0.5.15-136-arm64.img.xz
I did not want to destroy the environment of eMMC, so confirmed with microSD
Although slightly different from the main theme [microSD to eMMC]
Since the same error came out, I think that the essential problem has not changed.
"System -> Administration -> users - admin",
"System -> Administration -> Network",
"System -> Administration -> Time and Date"
These errors have disappeared
[Code]
# ls -la /usr/lib/dbus-1.0/dbus-daemon-launch-helper
-rwsr-xr - 1 root netdev 38824 Jan 12 2017 /usr/lib/dbus-1.0/dbus-daemon-launch-helper
# chown root:messagebus /usr/lib/dbus-1.0/dbus-daemon-launch-helper
# chmod u+s /usr/lib/dbus-1.0/dbus-daemon-launch-helper
-rwsr-xr - 1 root messagebus 38824 Jan 12 2017 /usr/lib/dbus-1.0/dbus-daemon-launch-helper
Information source is ↓.
dialog with error
"org.freedesktop.DBus.Error.Spawn.ExecFailed: Failed to execute program org.blueman.Mechanism: Permission denied"
displayed after login
https://bugs.launchpad.net/ubuntu/+sourc...ug/1542723
However, "Stikky-Bit" will come off when you do this street operation.
I think that the reverse order is better
(03-14-2018, 04:14 AM)t4_4t Wrote: "Failed to execute program org.freedesktop.systemtoolsbackends permission denied."
I confirmed about.
[Code]
dialog with error
Thanks to t4_4t for this.Cool  I tried this out and it's now working, I can access the admin and network function on MATE.
I can confirm that the two commands together are necessary:
sudo chown root:messagebus /usr/lib/dbus-1.0/dbus-daemon-launch-helper
sudo chmod u+s /usr/lib/dbus-1.0/dbus-daemon-launch-helper
Seems to work now. Thanks!
  Xen hypervisor on Rock64 tumbleweed 6 9,684 Yesterday, 09:25 AM
Last Post: darkfader
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 9 15,792 07-20-2025, 01:00 PM
  Rock64 - not booting after Armbian update helpmerock 6 3,656 03-27-2025, 08:26 AM
  can rock64 4gb ram run entirely on free software? heocb 1 2,358 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,487 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  problem with debian emmc boot G4zCDzWb 10 8,460 11-01-2024, 04:32 PM
Last Post: bits
  arch rock64 does not boot nemnob 1 3,516 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 68,536 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 100,206 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 4,433 03-14-2024, 03:09 AM
