A good desktop experience on Rock64
#21
Path to script: /usr/local/sbin
(03-17-2018, 01:25 PM)Luke Wrote: Path to script: /usr/local/sbin
so the command should be ./usr/local/sbin/install_desktop.sh lxde ?
perhaps i am missing something obvious, but
sudo ./install install_desktop.sh lxde
fails, even if you are in the correct directory, right?
yeah, you are missing something. the command is
sudo ./install_desktop.sh lxde
from the proper directory, /usr/local/sbin
not sure were your second install came from. also check for proper permissions on that file.
(03-17-2018, 07:58 PM)dkryder Wrote: yeah, you are missing something. the command is
The second install came from the first post...
For me the command ran but failed with dependencies errors (ffmepg and mpv iirc)
And only in case there where some pathing error on the script i did a:
cd /usr/loca/sbin
oh that, an obvious attempt to mess with the noobs. +1 for you.
my perception of the obvious borders on the phenomenal
thank you for helping me to not feel insane fora few moments
Corrected the first post ... must have gotten distracted while typing out the instructions. My apologies.
I have Linux from ayufan version 0.6.25 (updated from 0.6.23).
I tried to install lxde, mate and gnome, all the installation goes without errors but after restarting see a black screen. (when removing installed packages, I noticed that the system reported that there were no packages already installed, although there were no errors during installation)
On the newly downloaded 0.6.25 and written to a clean memory card, the graphical environment is not installed at all with the errors of the ffmpeg and MPV dependencies
p. s. sorry for my English Smile
Starting with 0.6.34 Bionic with LXDE is available for download; no need to install the desktop and related packages manually.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 153 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,373 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 338 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 619 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 613 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,424 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,732 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 593 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 652 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,459 12-07-2022, 08:22 PM
Last Post: luminosity7
