Which OS is better to run on ROCK64?
#21
(12-11-2018, 05:11 PM)pantera Wrote: You've missed my entire point. I meant polling in GPIO terms and inexcusable to Pine.  As a software engineer, I should be able to set callbacks and not constantly interrogate the pins for voltage.
And you missed mine. It works for me. Simple as that.
As I said the GPIO pins situation is easily sorted with a Raspberry Pi, tried and tested for the job.
As a software engineer you above anyone should know when you embrace new untried and untested hardware with limited reference resources you are working at the bleeding edge and either come up with a solution of your own or move on to something that you can work with.
What I will say its a powerful piece of kit for the price and specifically for what I bought it for. I'm surprised a person with your level of expertise bought into something that clearly was not suitable for your purposes.
In this case my glass was half full and yours half empty. As far as I'm aware the supplier will refund your purchase price or there is a healthy used market demand for them out there. Clearly it is of no value to you at this stage.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 152 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,365 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 337 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 615 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 610 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,391 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 190,588 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 592 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 651 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,421 12-07-2022, 08:22 PM
Last Post: luminosity7
