Cant'n install x11 on debian stretch
Cant'n install x11 on debian-stretch-minimal-rock64-0.6.15-175-arm64.img
sudo apt-get install xorg, dos not function. Does anyone know of a solution to the problem ?
(01-27-2018, 07:26 AM)Chris66 Wrote: Cant'n install x11 on debian-stretch-minimal-rock64-0.6.15-175-arm64.img
If you want a desktop, try apt-get install task-mate-desktop
Hi evilbunny - Thanks for your suggestion,
I have already tried the script, which however gives a lot of message about missing program packages and not compatible packages.
Have also tested the other suggestions, regarding Debian desktop, in this forum, but nothing works on my Rock64 with 4GB of RAM, that I received on January 8th, 2018, from Pine64.
It should also be mentioned that bionic-minimal-rock64-0.6.15 -175-arm64. img. XZ works impeccable, with X11 and LXDE. The only problem I have with it is that there is the commercial company behind which I am not happy with.
(01-28-2018, 05:24 AM)Chris66 Wrote: Hi evilbunny - Thanks for your suggestion,
Have you tried using the debian mate image?
Also about missing packages you can usually fix this by:
sudo apt-get update
Yes, I've tried Debian Stretch Mate Community Build Image [MicroSD Boot] [0.5.15-136-20171222], which freezes desktop without menu, task-line and reboots desktop every time you use the keyboard or mouse. If you think it should work, then I'll give it a new try and see if I can install another desktop.
Tested Debian Stretch Mate Community Build Image [MicroSD Boot] [0.5.15-136-20171222] again.
Login screen OK. Start the desktop with 3 icons OK, but missing menu and task-line and it restarts the desktop everytime I try to open one of the icons or activate anything with the right mouse button and no option to get a terminal window to work in.
  problem with debian emmc boot G4zCDzWb 10 4,615 11-01-2024, 04:32 PM
Last Post: bits
  Debian installation via sd card oaFJSADBKV 0 476 10-12-2024, 10:24 AM
Last Post: oaFJSADBKV
  How to update/compile Debian 12.5? Wizardknight 3 2,142 03-29-2024, 05:01 AM
Last Post: gedas07
  Rock64 Debian 11 (Bullseye) install problem jbize 15 14,696 10-12-2023, 05:14 PM
Last Post: tpaul
  Managed to install Kubernetes digitaldaz 3 5,743 08-16-2022, 02:44 AM
Last Post: mmarkgilbert
  rock64-debian-mrfixit-190531.img.xz : missing /usr/lib/dri/rockchip_dri.so popi 5 7,246 08-12-2021, 04:55 AM
Last Post: igorp
  Debian build from mrfixit2001 Luke 18 34,412 05-17-2021, 02:35 AM
Last Post: Wizzard
  Debian kernel stuck at 4.4.167 Enig123 5 7,626 12-29-2020, 12:57 PM
Last Post: kwinz
  Debian (Vanilla) on Rock64 and eMMC - how ? as365n4 4 7,064 09-21-2020, 04:33 AM
Last Post: as365n4
  pcsx rearmed on rock64 debian stretch does not go fullscreen RockyBoulder 2 5,203 05-09-2020, 03:15 AM
Last Post: lawrencejd
