12-04-2017, 11:52 AM
OK, I suppose I have a setting problem somewhere, but I don't see it. My Pinebook running Ubuntu (up to date) is doing something weird with file timestamps. I noticed it when copying files to and from another computer running Win10.
Here are the symptoms:
I created a text file on my PB, saved it, and copied it to a USB drive. PB tells me the timestamp on the USB copy matches the file on the PB, and both are what you would expect for a file just created and saved - close to PB system time reported. Then I moved the thumb drive to my HP and inspected the file. Windows Explorer tells me the timestamp is 8 hours into the future! Then I edited the file and saved it under another name on the HP and copied back to the thumb drive. Both the copy on my HP and the USB drive agree with each other and properly reflect system clock. I move the drive back to the PB. Now PB tells me the new file reads 8 hours earlier than its system clock. System clocks on both machines report the same time and date.
Another clue to what is going on is any file edited on the PB and copied to a USB drive will cause my Win10 machine to claim there is a problem with the drive and wants me to authorize a scan to repair. If I tell it to do so, though it reports no problem found, something changes as I can remove and re-insert the drive and it doesn't cause a repeat of the warning - unless the PB modifies the file.
Is this a bug in Ubuntu? Is there some setting somewhere in Ubuntu that I need to change?
"Get your facts straight first, then distort them as you wish." -- Mark Twain
