Rock64 crash - spinlock lockup suspected on CPU (possibly thermal reason)
Hi, I often get an error spinlock lockup suspected on CPU#X where x is cpu core number from 0 to 3, one after another. When that occurs in terminal everything freezes and the only way is to reboot the device using force poweroff. It's popping up only under stress (at least 30-50% of all cores) in Chrome for instance. I'm using a 13x13x10 mm radiator with average quality thermal paste. Temperature is about 50-65 Celsius degrees. I'm using latest Ubuntu Artful build. Is it possible that it's caused by thermal issue? Hardware Issue? Or maybe it's because unstable distro?
Please go easy on me, I'm rather beginner.
After further investigation it looks like a chromium browser issue. No problems with eihter stress test and other browsers
Edit2:
It looks like a problem with kernel or drivers, I don't know. Apparently the issues appears also in case of other softwares.
I'm doing stress test using 3 chromium browsers running twitch.tv on stable 0.5.10 release and 0 issues here. Weird.
it might also be the sd card has a problem spot on the media surface. if not too dificult or costly try reflashing the o/s after doing a scan/test of the card.
  rAudio for Rock64 V2 shinzuka 9 1,217 06-05-2026, 06:22 AM
Last Post: shinzuka
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 12 18,281 03-07-2026, 11:04 AM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 965 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 5,729 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 11,643 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,089 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,260 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,308 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 85,279 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 109,347 09-01-2024, 06:05 AM
